[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams mfadams at lbl.gov
Thu May 19 10:03:42 CDT 2016
On Tue, May 17, 2016 at 10:55 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Mark,
>    So it sounds like the right fix is to change the "random" option name
> to "noisy" and replace the use of the random number generator with Jed's
> hash and make it the default. (Where if you turn off the noisy it uses the
> right hand side which is useful for debugging the solvers)
So this means removing "PetscRandom      random;" from Cheby, I assume.
> If you make a pull request we'll move it through,
>    Thanks for bringing up the problem,
>   Barry
> > On May 17, 2016, at 9:44 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Barry Smith <bsmith at mcs.anl.gov> writes:
> >>  So are you proposing we have three options
> >>  KSPChebyshevEstEigSetRHSType() with (1) "use give rhs", (2) "use
> >>  random rhs", (3) "use hash scheme to produce same right hand side
> >>  independent of number of processes so long as the ordering stays the
> >>  same" or are you suggesting just bagging the random?
> > Bag random for sure.
> >>  or bagging also the right hand side and always just use the hash
> >>  scheme?
> > I wouldn't have a problem with that.  The only nice thing about using
> > the RHS is that it doesn't depend on the ordering.
> >>  By just using the hash scheme we can remove some current code and
> >>  options which is always a good thing... if they provide no added
> >>  value then they should be removed.
> > Yes.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160519/6c2cbc1b/attachment.html>
