[petsc-dev] strangness in Chebyshev estimate of eigenvalues
    Jed Brown
    jed at jedbrown.org
    Tue May 17 21:44:23 CDT 2016
Barry Smith <bsmith at mcs.anl.gov> writes:
>   So are you proposing we have three options
>   KSPChebyshevEstEigSetRHSType() with (1) "use give rhs", (2) "use
>   random rhs", (3) "use hash scheme to produce same right hand side
>   independent of number of processes so long as the ordering stays the
>   same" or are you suggesting just bagging the random?
Bag random for sure.
>   or bagging also the right hand side and always just use the hash
>   scheme?
I wouldn't have a problem with that.  The only nice thing about using
the RHS is that it doesn't depend on the ordering.
>   By just using the hash scheme we can remove some current code and
>   options which is always a good thing... if they provide no added
>   value then they should be removed.
Yes.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160517/7d984eb9/attachment.sig>
