[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Tue May 17 14:41:05 CDT 2016
On Tue, May 17, 2016 at 2:34 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > Should we just make this another Random implementation which is only for
> > testing?
> The problem is that we want to produce the same numbers on one process
> and on many processes.  The interface doesn't really afford that because
> it provides a stream of numbers.  If we know the number of entries we're
> about to ask for on each process, we could do a Scan to find the
> starting index and "seed" with that, where drawing a number hashes and
> increments the counter.  But this is pretty contorted.
It seems like we should do double dispatch for VecSetRandom().
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160517/c751397d/attachment.html>
