[petsc-dev] asm / gasm
Fande Kong fdkong.jd at gmail.com
Sun Jun 26 10:43:52 CDT 2016
Mark,
Size of the index set is smaller than size of pmat in your case?  They
should be the same. I do not think we ever considered the index set has a
different size from that of Pmat.
Fande,
On Sun, Jun 26, 2016 at 7:09 AM, Mark Adams <mfadams at lbl.gov> wrote:
> GASM does assume the index set includes every equation in the matrix.  It
> should probably check this as it has pmat.
> I guess I can add these BC vertices in.
> On Sun, Jun 26, 2016 at 11:20 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> Fande,
>> An alternative debug path that may be simpler and direct, as it works
>> with master:  'make runex56' in ksp/examples/tutorials in
>> branch mark/gamg-agg-asm.
>> This runs clean in valgrind (for me), I've added an ISView call to see
>> the data that causes the error, it runs on one processor, uses a 3^3 cell
>> grid (tiny), it exits cleanly with the error:
>> 87 189
>> 88 190
>> 89 191
>> > [0]PETSC ERROR: --------------------- Error Message
>> > [0]PETSC ERROR: Argument out of range
>> > [0]PETSC ERROR: Index 144 at 42 location greater than max 144
>> [0]PETSC ERROR: #1 VecScatterCheckIndices_Private() line 39 in
>> /Users/markadams/Codes/petsc/src/vec/vec/utils/vscat.c
>> [0]PETSC ERROR: #2 VecScatterCreate() line 1227 in
>> [0]PETSC ERROR: #3 PCSetUp_GASM() line 481 in
>> /Users/markadams/Codes/petsc/src/ksp/pc/impls/gasm/gasm.c
>> This index 144 is very suspicious to me because there are 144 REAL dofs
>> in this test, 192 "gross" dofs, minus (48) boundary conditions. This
>> problem has just two aggregates with sizes 54 & 90 (=144). (I strip out the
>> BC vertices.)
>> Maybe GASM is getting confused because I do not give it domains that
>> cover the entire mesh (I strip out BC vertices).  GASM thinks there are 144
>> equations in this system when in fact there are 192.
>> It looks to me like GASM is working a space stripped of BCs but it is
>> using my indices that are in the full space.
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160626/7d7c93ab/attachment.html>
