[petsc-dev] asm / gasm
Mark Adams
mfadams at lbl.gov
Wed Jun 22 22:20:02 CDT 2016
> No joke, Amneet found that PCASM with lots of small subdomains was
> spending a ton of time in view calls.
> (And, of course, Barry fixed it by adding this configure flag --- thanks
> Barry!)
> Note that it does not matter whether you *use* view or not.
Oh wow. So no view with ASM,
Garth, you will need to configure with '--with-viewfromoptions=0'
> -- Boyce
> -- Boyce
> I guess we should have a flag or not iterate over the blocks in ASMView ...
>> -- Boyce
>> Barry
>> On Jun 22, 2016, at 7:51 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> I'm trying to get block smoothers to work for gamg. We (Garth) tried
>> this and got this error:
>> - Another option is use '-pc_gamg_use_agg_gasm true' and use
>> '-mg_levels_pc_type gasm'.
>> Running in parallel, I get
>> ** Max-trans not allowed because matrix is distributed
>> First, what is the difference between asm and gasm?
>> Second, I need to fix this to get block smoothers. This used to work.
>> Did we lose the capability to have blocks that span processor subdomains?
>> gamg only aggregates across processor subdomains within one layer, so
>> maybe I could use one layer of overlap in some way?
>> Thanks,
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160623/634dc3d7/attachment.html>
