[petsc-dev] NEVER put // into PETSc code. PETSc is C89, the only real C.
Sean Farley sean at farley.io
Wed Jun 22 18:33:06 CDT 2016
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Hmm, both of these links refer to C99 Standard Library  they do not refer to the C99 standard language. Anywhere that says the language standard?
Good question. It's getting dangerously close to beer o'clock for me but
if you have a test, we could just try running that on a vm.
