[petsc-dev] Bug in MatZeroRows_MPIAIJ
Tue Jun 21 16:30:15 CDT 2016
   Most definitely a bug. If it all possible let's keep the code self contained here and not require flags set in other parts of the code because that could easily led to confusion and bugs in the future.
   Why not just remove the first if test (below) and just have the two conditions diag != 0.0 and drag == 0.0
     if ((diag != 0.0) && (mat->A->rmap->N == mat->A->cmap->N)) {
        ierr = MatZeroRows(mat->A, len, lrows, diag, NULL, NULL);CHKERRQ(ierr);
  and also drop the
if (((Mat_SeqAIJ *) mat->A->data)->nonew) SETERRQ(PETSC_COMM_SELF, PETSC_ERR_SUP, "MatZeroRows() on rectangular matrices cannot be used with the Mat options\nMAT_NEW_NONZERO_LOCATIONS,MAT_NEW_NONZERO_LOCATION_ERR,MAT_NEW_NONZERO_ALLOCATION_ERR");
test since the appropriate error will still be generated internally.
   Simplier code is always better code.
   Barry
> On Jun 21, 2016, at 1:55 PM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> I think that the test
> at line 836 in src/mat/impls/aij/mpi/mpiaij.c (master) is a bug, either for rectangular matrices or even for square matrices with non-trivial layouts.
> It can happen that some of the processes does not satisfy the test and some others do; in this case, MatAssemblyBegin/End is not  collectively called.
> I don’t see any trivial fix; my solution involves computing a flag during MatSetSizes() based on some test on the ranges of the row and column layouts.
> I will go on and fix it in a branch unless someone has a simpler solution.
