[petsc-dev] Bug in MatZeroRows_MPIAIJ
Stefano Zampini stefano.zampini at gmail.com
Tue Jun 21 13:55:56 CDT 2016
I think that the test
if ((diag != 0.0) && (mat->A->rmap->N == mat->A->cmap->N)) {
at line 836 in src/mat/impls/aij/mpi/mpiaij.c (master) is a bug, either for rectangular matrices or even for square matrices with non-trivial layouts.
It can happen that some of the processes does not satisfy the test and some others do; in this case, MatAssemblyBegin/End is not  collectively called.
I don’t see any trivial fix; my solution involves computing a flag during MatSetSizes() based on some test on the ranges of the row and column layouts.
I will go on and fix it in a branch unless someone has a simpler solution.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160621/6aa279e7/attachment.html>
