[petsc-dev] consequences of setting KSP_NORM_TYPE to NONE
Sun Jun 12 21:59:47 CDT 2016
   This looks like a reasonable fix for me. The manual page should indicate that it changes the convergence test if you change from no norm.
   Barry
> On Jun 12, 2016, at 2:51 PM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> As of today, a code like this
> KSPSetNormType(ksp,KSP_NORM_NONE);
> KSPSetFromOptions(ksp);
> will produce a KSP that will always skip the convergence tests, even if we specify -ksp_norm_type whatever at command line. Is this the expected behavior?
> If not, a tentative patch is attached.
> <fix_norm_type_none.diff>
