[petsc-dev] consequences of setting KSP_NORM_TYPE to NONE
Stefano Zampini stefano.zampini at gmail.com
Sun Jun 12 14:51:07 CDT 2016
As of today, a code like this
KSPSetNormType(ksp,KSP_NORM_NONE);
KSPSetFromOptions(ksp);
will produce a KSP that will always skip the convergence tests, even if we specify -ksp_norm_type whatever at command line. Is this the expected behavior?
If not, a tentative patch is attached.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160612/c7d6ab67/attachment.obj>
