[petsc-dev] Configure push
Mon Jun 6 18:20:02 CDT 2016
On Mon, Jun 6, 2016 at 11:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    In order to allow decent pre-testing before merging to next I had Jason
> write a shell script to talk to a Jenkins server and organize a Jenkins
> server to accept such tests with decent turn around. Little did I know how
> rigid Jenkins is in how it wants to do things; so the final result was just
> too cumbersome to deal with websites and job numbers ....
>    I'd like us to try again this time with just ssh and simple scripts
> (Jenkins is just not suitable). From the user point of view one would be in
> a git branch such as
> ~/Src/petsc (my-cool-branch=)
> $ ./bin/submittest options
> depending on options and a configuration file it would launch a series of
> tests on the local machine or any another machine you have ssh keys for. It
> could even have an option like --merge-to-next where in the tests it merges
> the branch into next automatically before running the tests. The jobs would
> all be run (even on the local machine) off of other clones so wouldn't
> interfere with your own work. By default it would run a few cases that
> usually mess up, a complex, a quad precision, a c++, a 64 bit integer etc.
> this will catch most basic errors.
I like this very much. I would also be happy with just email responses,
although I do not see why we don't just use the current filter for the
nightly runs on it.
Just let me know what we have and I will start using it.
    Matt
> The biggest API question I have is how to "get the results back to you".
> Should it email results from each job as it comes (or just failures), try
> to batch the results from all jobs together. Is email even always possible
> from the crazy machine it is sshing to? Do we have copy the results back
> from remote machines and put in some magic place you can read? How to tell
> you they are done? A text message? Update some website?  I think I would be
> happy with an email on each failure (I can start fixing stuff right away)
> and a final email once all tests are done telling me they are all done. So
> I know the tests are all done). What about advanced things liking killing
> tests you've started because you already got a failure and fixed it and
> resubmitted. This could get complex; or not. I know, let's use XXX to do
> this.
>    Barry
> > On Jun 6, 2016, at 4:44 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Mon, Jun 6, 2016 at 7:08 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Mon, 6 Jun 2016, Matthew Knepley wrote:
> > > On Mon, Jun 6, 2016 at 5:27 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > Matt,
> > > > Per integration workflow - all feature branches should be tested
> > > > locally (and be complete) - before merged to next [next is for
> > > > integration testing - not feature testing]
> > > > You could have used (modified):
> > > > config/examples/arch-linux-xsdk-dbg.py
> > > > config/examples/arch-osx-xsdk-opt.py
> > > > Yeah - we don't have automatic 'feature branch test before
> integration
> > > > testing' workflow - so currently this has to be done manually.
> > > I don't really have the OS/compiler options available to test things
> > > exhaustively, so I am
> > > using next for this. I think this is acceptable right now.
> > Well then the feature is not yet ready for next - and could have
> > waited until it was ready.
> > I do nto agree here. Just because some Git nerd thinks that 'next'
> should be
> > that way does not mean it is what makes us most productive. I think we
> are way
> > more productive using the nightly tests as a way to discover bugs. I
> cannot waste
> > my personal time running a bunch of tests on my own slow laptop before
> pushing.
> >   Matt
> > If it was for someone to use - then they could have used the
> > feature-branch..
> > The workflow requires the feature to be complete - and minimally
> > tested - before merge to next.. We do ocassionally take shortcuts -
> > but this sometimes this results in extended broken next...
> > Satish
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160607/4bcec7bf/attachment.html>
