[petsc-dev] slow loading of mesh in dmplex
Tobin Isaac tisaac at uchicago.edu
Fri Jul 29 08:52:59 CDT 2016
Hi Stephan,
Thanks for this!  I switched the internal storage of label strata to
an IS to allow greater flexibility, but I admit to rotely throwing
ISGetIndices/ISRestoreIndices around sections of code that I didn't
take the time to understand fully.  I'll get this integrated.
Cheers,
  Toby
On Fri, Jul 29, 2016 at 11:53:12AM +0100, Stephan Kramer wrote:
> Dear petsc devs
> After some profiling of the loading of a large gmsh mesh in dmplex
> (which seemed to take forever), I found that it was spending 99% of
> its time in IsGetIndices_Stride in the following calltree
> DMPlexCreateGmshFromFile -> DMPlexGetFullJoin ->
> DMLabelGetStratumBounds -> ISGetIndices -> ISGetIndices_Stride
> where it seems to work out the bounds of each stratum by explicitly
> computing all indices of a strided index set to then only take its
> first and last entry, and this is done for each facet in the mesh a
> couple of times.
> With the attached patch I managed to reduce the load time of a mesh
> from 4 hours to 22 seconds! I'm not a 100% sure if the patch is
> correct in all circumstances: I presume the assumption was that the
> index set is sorted?
> Cheers
> Stephan
> diff --git a/src/dm/label/dmlabel.c b/src/dm/label/dmlabel.c
> index f3e784c..fb8d1b9 100644
> --- a/src/dm/label/dmlabel.c
> +++ b/src/dm/label/dmlabel.c
> @@ -770,15 +770,14 @@ PetscErrorCode DMLabelGetStratumBounds(DMLabel label, PetscInt value, PetscInt *
>    if (start) {PetscValidPointer(start, 3); *start = 0;}
>    if (end)   {PetscValidPointer(end,   4); *end   = 0;}
>    for (v = 0; v < label->numStrata; ++v) {
> -    const PetscInt *points;
> +    PetscInt min, max;
>      if (label->stratumValues[v] != value) continue;
>      ierr = DMLabelMakeValid_Private(label, v);CHKERRQ(ierr);
>      if (label->stratumSizes[v]  <= 0)     break;
> -    ierr = ISGetIndices(label->points[v],&points);CHKERRQ(ierr);
> -    if (start) *start = points[0];
> -    if (end)   *end   = points[label->stratumSizes[v]-1]+1;
> -    ierr = ISRestoreIndices(label->points[v],&points);CHKERRQ(ierr);
> +    ierr = ISGetMinMax(label->points[v], &min, &max);CHKERRQ(ierr);
> +    if (start) *start = min;
> +    if (end)   *end   = max+1;
>      break;
>    PetscFunctionReturn(0);
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160729/b8b8225f/attachment.sig>
