[petsc-dev] p4est configure error
Thu Jul 7 15:35:53 CDT 2016
                  Looking for P4EST at git.p4est, hg.p4est or a directory starting with p4est
                  Found a copy of P4EST in git.p4est
Executing: ['git', 'rev-parse', '--git-dir']
stdout: .git
Executing: ['git', 'fetch']
Executing: ['git', 'rev-parse', 'origin/petsc']
stdout: a9f222be3099d0ca3aa19e2fe3d1aa0614491357
<snip>
Executing: ['git', 'checkout', '-f', 'a9f222be3099d0ca3aa19e2fe3d1aa0614491357']
https://github.com/tisaac/p4est/commits/petsc a9f222b Is the latest commit in this branch - so
configure is using the correct p4est snapshot..
> /usr/bin/ld: attempted static link of dynamic object `/opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so'
Looks like some libtool issue..
Satish
On Thu, 7 Jul 2016, Mark Adams wrote:
> I nuked and ran this twice:
> 1013  rm -fr arch-xc30-dbg64-intel
>  1014  ../arch-xc30-dbg64-intel.py
>  1015  h
>  1016  ../arch-xc30-dbg64-intel.py
> Same error.
> On Thu, Jul 7, 2016 at 9:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > perhaps configure was not rerun - so a stale p4est was being used..
> > Satish
> > On Thu, 7 Jul 2016, Tobin Isaac wrote:
> > > p4est.py automatically pulls from whatever p4est branch I call 'petsc'
> > > in my repo, so I don't see how this problem persists if you really
> > > nuked it.
> > > - Did you nuke the right directory?
> > > - Did you send me the right configure.log?
> > > - Is the new failure the same (the same stale p4est commit is being
> > >   used)?
> > > On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
> > > > It sounds like I have not merged your fix.  Should I pull from master?
> > > > I have nuked this many times.
> > > > On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <tisaac at uchicago.edu>
> > wrote:
> > > > > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
> > > > > > p4est on Edison configures in w/o debugging, although I have to run
> > > > > > configure twice.
> > > > > > But with debugging it fails.  I can not see any difference between
> > the
> > > > > two
> > > > > > configures other than debugging.
> > > > > > Mark
> > > > > The log shows that you are configuring a p4est commit (3d3e1) that is
> > > > > before the one I pushed specifically to avoid the fortran
> > > > > configuration error (f54bb3).  Please clear the git.p4est directory,
> > > > > and confirm that you are configuring with the current 'petsc' branch
> > > > > of p4est (`grep 'checking Point version' configure.log` should show
> > > > > X.XXX-a9f22).
> > > > > Cheers,
> > > > >   Toby
