[petsc-dev] p4est configure error
Mark Adams mfadams at lbl.gov
Thu Jul 7 15:27:23 CDT 2016
I nuked and ran this twice:
1013  rm -fr arch-xc30-dbg64-intel
 1014  ../arch-xc30-dbg64-intel.py
 1015  h
 1016  ../arch-xc30-dbg64-intel.py
Same error.
On Thu, Jul 7, 2016 at 9:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> perhaps configure was not rerun - so a stale p4est was being used..
> Satish
> On Thu, 7 Jul 2016, Tobin Isaac wrote:
> > p4est.py automatically pulls from whatever p4est branch I call 'petsc'
> > in my repo, so I don't see how this problem persists if you really
> > nuked it.
> > - Did you nuke the right directory?
> > - Did you send me the right configure.log?
> > - Is the new failure the same (the same stale p4est commit is being
> >   used)?
> > On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
> > > It sounds like I have not merged your fix.  Should I pull from master?
> > > I have nuked this many times.
> > > On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <tisaac at uchicago.edu>
> wrote:
> > > > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
> > > > > p4est on Edison configures in w/o debugging, although I have to run
> > > > > configure twice.
> > > > > But with debugging it fails.  I can not see any difference between
> the
> > > > two
> > > > > configures other than debugging.
> > > > > Mark
> > > > The log shows that you are configuring a p4est commit (3d3e1) that is
> > > > before the one I pushed specifically to avoid the fortran
> > > > configuration error (f54bb3).  Please clear the git.p4est directory,
> > > > and confirm that you are configuring with the current 'petsc' branch
> > > > of p4est (`grep 'checking Point version' configure.log` should show
> > > > X.XXX-a9f22).
> > > > Cheers,
> > > >   Toby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160707/cfe49bd9/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160707/cfe49bd9/attachment.obj>
