[petsc-dev] Always compiling and installing Ctetgen even without updates
Jed Brown jed at jedbrown.org
Thu Jan 28 00:42:57 CST 2016
Satish Balay <balay at mcs.anl.gov> writes:
> But tetgen depends on petsc includes - so a pull could change any of
> these files [so somehow all include deps should be tracked?]
Naturally.  I would do this by adding an include (listing ctetgen
sources and target lib) to gmakefile (supporting the same for other
build systems is more of a hassle).
However, I think this is a crappy way to distribute software and Matt
should have kept ctetgen a stand-alone package instead of inlining it
into PETSc source tree (which broke the license terms) and then having
it be only partially divorced.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160127/7337c7ee/attachment.sig>
