[petsc-dev] Always compiling and installing Ctetgen even without updates
Jed Brown jed at jedbrown.org
Thu Jan 28 00:13:01 CST 2016
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Yes, but if petscconf.h is identical a super smart dependency checker would see it was unchanged.  Worth doing? Probably not.
Checksum the existing petscconf.h and the provisional petscconf.h.  If
they match, return without modifying the file.  If not, overwrite it
(what we do now).  Then standard make dependencies will work.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160127/d217a921/attachment.sig>
