[petsc-dev] petsc-master bug? "Too many pushes"
Wed Jan 27 10:49:23 CST 2016
  Sorry about that. Fixed in master.
  Barry
> On Jan 27, 2016, at 8:23 AM, Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi,
> since dec 15, we compile and test our code with the nightly "petsc-master" tarball (http://ftp.mcs.anl.gov/pub/petsc/petsc-master.tar.gz)
> and everything was fine until this morning.
> I noticed 4 tests in error:
> 0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: Too many pushes
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.6.3-2098-g5826409 GIT Date: 2016-01-26 20:32:46 -0600
> (see full traceback.txt file and kspview.txt file)
> If you look at kspview.txt, you will see that the KspView is abruptly ended at the end of file, at "Factored matrix follows:"
> This resolution implies multiple nested matrices, and was running fine until this morning.
> Any ideas? Can you guide me to what to check?
> Thanks,
> Eric
> <traceback.txt><kspview.txt>
