[petsc-dev] petsc-master bug? "Too many pushes"
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Wed Jan 27 08:23:21 CST 2016
since dec 15, we compile and test our code with the nightly
"petsc-master" tarball
(http://ftp.mcs.anl.gov/pub/petsc/petsc-master.tar.gz)
and everything was fine until this morning.
I noticed 4 tests in error:
0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: Too many pushes
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.6.3-2098-g5826409
GIT Date: 2016-01-26 20:32:46 -0600
(see full traceback.txt file and kspview.txt file)
If you look at kspview.txt, you will see that the KspView is abruptly
ended at the end of file, at "Factored matrix follows:"
This resolution implies multiple nested matrices, and was running fine
until this morning.
Any ideas? Can you guide me to what to check?
Eric
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.6.3-2098-g5826409  GIT Date: 2016-01-26 20:32:46 -0600
[0]PETSC ERROR: /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/GIREF/bin/Test.ProblemeGD.dev on a arch-linux2-c-debug named compile by Unknown Wed Jan 27 03:09:57 2016
[0]PETSC ERROR: Configure options --prefix=/opt/petsc-master_debug --with-mpi-compilers=1 --with-make-np=12 --with-shared-libraries=1 --with-mpi-dir=/opt/openmpi-1.6.5_rh6 --with-debugging=yes --with-mkl_pardiso=1 --with-mkl_pardiso-dir=/opt/intel/composerxe/mkl --download-ml=yes --download-mumps=yes --download-superlu=yes --download-superlu_dist=yes --download-parmetis=yes --download-ptscotch=yes --download-metis=yes --download-suitesparse=yes --download-hypre=yes --with-scalapack=1 --with-scalapack-include=/opt/intel/composerxe/mkl/include --with-scalapack-lib="-L/opt/intel/composerxe/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64" --with-blas-lapack-dir=/opt/intel/composerxe/mkl/lib/intel64
[0]PETSC ERROR: #1 PetscViewerPushFormat() line 149 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/sys/classes/viewer/interface/viewa.c
[0]PETSC ERROR: #2 PCView_Factor() line 324 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/pc/impls/factor/factimpl.c
[0]PETSC ERROR: #3 PCView_Cholesky() line 73 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/pc/impls/factor/cholesky/cholesky.c
[0]PETSC ERROR: #4 PCView() line 1717 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #5 KSPView() line 213 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/ksp/interface/itcreate.c
[0]PETSC ERROR: #6 MatView_SchurComplement() line 59 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/ksp/utils/schurm.c
[0]PETSC ERROR: #7 MatView() line 886 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
[0]PETSC ERROR: #8 PCView() line 1734 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #9 KSPView() line 213 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/ksp/interface/itcreate.c
[0]PETSC ERROR: #10 PCView_FieldSplit_Schur() line 221 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #11 PCView() line 1717 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #12 KSPView() line 213 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/ksp/interface/itcreate.c
[0]PETSC ERROR: #13 MatView_SchurComplement() line 59 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/ksp/utils/schurm.c
[0]PETSC ERROR: #14 MatView() line 886 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
[0]PETSC ERROR: #15 PCView() line 1734 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #16 KSPView() line 213 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/ksp/interface/itcreate.c
[0]PETSC ERROR: #17 PCView_FieldSplit_Schur() line 221 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #18 PCView() line 1717 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #19 KSPView() line 213 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/ksp/interface/itcreate.c
[0]PETSC ERROR: #20 PetscObjectView() line 106 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/sys/objects/destroy.c
[0]PETSC ERROR: #21 PetscObjectViewFromOptions() line 2739 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/sys/objects/options.c
[0]PETSC ERROR: #22 KSPSolve() line 822 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/ksp/ksp/interface/itfunc.c
KSP Object:(systeme_) 1 MPI processes
  type: gmres
    GMRES: restart=50, using Modified Gram-Schmidt Orthogonalization
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=150, initial guess is zero
  tolerances:  relative=0.001, absolute=1e-18, divergence=1e+08
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object:(systeme_) 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from user provided matrix
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (precondHP__HP)       1 MPI processes
        type: preonly
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        left preconditioning
        using NONE norm type for convergence test
      PC Object:      (precondHP__HP)       1 MPI processes
        type: fieldsplit
          FieldSplit with Schur preconditioner, factorization LOWER
          Preconditioner for the Schur complement formed from A11
          Split info:
            KSP Object:            (cholesky_)             1 MPI processes
              type: preonly
            PC Object:            (cholesky_)             1 MPI processes
              type: cholesky
                Cholesky: out-of-place factorization
                tolerance for zero pivot 2.22045e-14
                matrix ordering: natural
                factor fill ratio given 0., needed 0.
                    Mat Object:                     1 MPI processes
                      type: seqsbaij
                      rows=16, cols=16
                      package used to perform factorization: mumps
                      total: nonzeros=0, allocated nonzeros=16
                      total number of mallocs used during MatSetValues calls =0
                        MUMPS run parameters:
                          SYM (matrix type):                   2
                          PAR (host participation):            1
                          ICNTL(1) (output for error):         6
                          ICNTL(2) (output of diagnostic msg): 0
                          ICNTL(3) (output for global info):   0
                          ICNTL(4) (level of printing):        0
                          ICNTL(5) (input mat struct):         0
                          ICNTL(6) (matrix prescaling):        7
                          ICNTL(7) (sequentia matrix ordering):5
                          ICNTL(8) (scalling strategy):        77
                          ICNTL(10) (max num of refinements):  0
                          ICNTL(11) (error analysis):          0
                          ICNTL(12) (efficiency control):                         0
                          ICNTL(13) (efficiency control):                         0
                          ICNTL(14) (percentage of estimated workspace increase): 33
                          ICNTL(18) (input mat struct):                           0
                          ICNTL(19) (Shur complement info):                       0
                          ICNTL(20) (rhs sparse pattern):                         0
                          ICNTL(21) (solution struct):                            0
                          ICNTL(22) (in-core/out-of-core facility):               0
                          ICNTL(23) (max size of memory can be allocated locally):0
                          ICNTL(24) (detection of null pivot rows):               0
                          ICNTL(25) (computation of a null space basis):          0
                          ICNTL(26) (Schur options for rhs or solution):          0
                          ICNTL(27) (experimental parameter):                     -24
                          ICNTL(28) (use parallel or sequential ordering):        1
                          ICNTL(29) (parallel ordering):                          0
                          ICNTL(30) (user-specified set of entries in inv(A)):    0
                          ICNTL(31) (factors is discarded in the solve phase):    0
                          ICNTL(33) (compute determinant):                        0
                          CNTL(1) (relative pivoting threshold):      0.01
                          CNTL(2) (stopping criterion of refinement): 1.49012e-08
                          CNTL(3) (absolute pivoting threshold):      0.
                          CNTL(4) (value of static pivoting):         -1.
                          CNTL(5) (fixation for null pivots):         0.
                          RINFO(1) (local estimated flops for the elimination after analysis):
                            [0] 288.
                          RINFO(2) (local estimated flops for the assembly after factorization):
                            [0]  20.
                          RINFO(3) (local estimated flops for the elimination after factorization):
                            [0]  288.
                          INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
                          [0] 1
                          INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
                            [0] 1
                          INFO(23) (num of pivots eliminated on this processor after factorization):
                            [0] 16
                          RINFOG(1) (global estimated flops for the elimination after analysis): 288.
                          RINFOG(2) (global estimated flops for the assembly after factorization): 20.
                          RINFOG(3) (global estimated flops for the elimination after factorization): 288.
                          (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
                          INFOG(3) (estimated real workspace for factors on all processors after analysis): 96
                          INFOG(4) (estimated integer workspace for factors on all processors after analysis): 108
                          INFOG(5) (estimated maximum front size in the complete tree): 6
                          INFOG(6) (number of nodes in the complete tree): 4
                          INFOG(7) (ordering option effectively use after analysis): 5
                          INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
                          INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 96
                          INFOG(10) (total integer space store the matrix factors after factorization): 108
                          INFOG(11) (order of largest frontal matrix after factorization): 6
                          INFOG(12) (number of off-diagonal pivots): 0
                          INFOG(13) (number of delayed pivots after factorization): 0
                          INFOG(14) (number of memory compress after factorization): 0
                          INFOG(15) (number of steps of iterative refinement after solution): 0
                          INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 1
                          INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 1
                          INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 1
                          INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 1
                          INFOG(20) (estimated number of entries in the factors): 64
                          INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 1
                          INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 1
                          INFOG(23) (after analysis: value of ICNTL(6) effectively used): 5
                          INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
                          INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
                          INFOG(28) (after factorization: number of null pivots encountered): 0
                          INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 64
                          INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 0, 0
                          INFOG(32) (after analysis: type of analysis done): 1
                          INFOG(33) (value used for ICNTL(8)): -2
                          INFOG(34) (exponent of the determinant if determinant is requested): 0
              linear system matrix = precond matrix:
              Mat Object:              (cholesky_)               1 MPI processes
                type: seqsbaij
                rows=16, cols=16
                total: nonzeros=64, allocated nonzeros=64
                    block size is 1
          KSP solver for S = A11 - A10 inv(A00) A01
            KSP Object:            (ssor_)             1 MPI processes
              type: preonly
            PC Object:            (ssor_)             1 MPI processes
              type: sor
                SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
              linear system matrix followed by preconditioner matrix:
              Mat Object:              (precondHP__HPfieldsplit_schur_)               1 MPI processes
                type: schurcomplement
                rows=68, cols=68
                  Schur complement A11 - A10 inv(A00) A01
                  A11
                    Mat Object:                    (solveurHP__HPfieldsplit_a_11_)                     1 MPI processes
                      type: seqaij
                      rows=68, cols=68
                      total: nonzeros=1280, allocated nonzeros=1280
                        using I-node routines: found 28 nodes, limit used is 5
                  A10
                    Mat Object:                    (solveurHP__HPBlocsHDiag_)                     1 MPI processes
                      type: seqaij
                      rows=68, cols=16
                      total: nonzeros=389, allocated nonzeros=389
                        using I-node routines: found 26 nodes, limit used is 5
                  KSP of A00
                      type: preonly
                      type: cholesky
                              type: seqsbaij
                              rows=16, cols=16
                                    [0] 288.
                                    [0]  20.
                                    [0]  288.
                                  [0] 1
                                    [0] 1
                                    [0] 16
                        type: seqsbaij
                        rows=16, cols=16
                            block size is 1
                  A01
                      type: seqaij
                      rows=16, cols=68
                        using I-node routines: found 8 nodes, limit used is 5
                type: seqaij
                rows=68, cols=68
        Mat Object:        (solveurHP__HP)         1 MPI processes
          type: nest
          rows=84, cols=84
            Matrix object:
              type=nest, rows=2, cols=2
              MatNest structure:
              (0,0) : prefix="cholesky_", type=seqsbaij, rows=16, cols=16
              (0,1) : prefix="solveurHP__HPBlocsHDiag_", type=seqaij, rows=16, cols=68
              (1,0) : prefix="solveurHP__HPBlocsHDiag_", type=seqaij, rows=68, cols=16
              (1,1) : prefix="solveurHP__HPfieldsplit_a_11_", type=seqaij, rows=68, cols=68
      KSP Object:      (systeme_fieldsplit_lambda_)       1 MPI processes
        type: preonly
      PC Object:      (systeme_fieldsplit_lambda_)       1 MPI processes
        type: mat
        Mat Object:        (systeme_fieldsplit_lambda_)         1 MPI processes
          rows=8, cols=8
            A11
                type: seqaij
                rows=8, cols=8
                total: nonzeros=18, allocated nonzeros=18
                  using I-node routines: found 4 nodes, limit used is 5
            A10
              Mat Object:              ()               1 MPI processes
                type: seqaij
                rows=8, cols=84
                total: nonzeros=280, allocated nonzeros=280
            KSP of A00
                type: preonly
                type: fieldsplit
                  Split info:
                      type: preonly
                      type: cholesky
                              type: seqsbaij
                              rows=16, cols=16
                                    [0] 288.
                                    [0]  20.
                                    [0]  288.
                                  [0] 1
                                    [0] 1
                                    [0] 16
                        type: seqsbaij
                        rows=16, cols=16
                            block size is 1
                      type: preonly
                      type: sor
                        rows=68, cols=68
                          A11
                              type: seqaij
                              rows=68, cols=68
                          A10
                              type: seqaij
                              rows=68, cols=16
                          KSP of A00
                              type: preonly
                              type: cholesky
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
