[petsc-dev] snes_monitor_residual
Wed Dec 21 21:58:58 CST 2016
On Wed, Dec 21, 2016 at 9:53 PM, Mark Adams <mfadams at lbl.gov> wrote:
> You have to add code to get dm_view to work apparently.
> I have done this before. This is some hocus pocus that Toby gave me. Is
> this really the way?
>     PetscViewer       viewer = NULL;
>     PetscBool         flg;
>     PetscViewerFormat fmt;
>     ierr = DMViewFromOptions(dm,NULL,"-dm_view");CHKERRQ(ierr);
>     ierr = PetscOptionsGetViewer(ctx->wComm,NULL,"-x2_vec_view",&
> viewer,&fmt,&flg);CHKERRQ(ierr);
>     if (flg) {
>       ierr = PetscViewerPushFormat(viewer,fmt);CHKERRQ(ierr);
>       ierr = VecView(dmpi->phi,viewer);CHKERRQ(ierr);
>       ierr = VecView(dmpi->rho,viewer);CHKERRQ(ierr);
>       ierr = PetscViewerPopFormat(viewer);CHKERRQ(ierr);
>    ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
I can't see why you need this. Did the other options not work?
  Matt
> On Wed, Dec 21, 2016 at 2:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   How about adding a least some documentation to bin/petsc_gen_xdmf.py
>> > On Dec 21, 2016, at 1:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Wed, Dec 21, 2016 at 12:56 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > I ran with:
>> > -snes_monitor_residual hdf5:res.h5
>> > -snes_monitor_solution hdf5:sol.h5
>> > and got h5 files that look OK:
>> > That will stash vectors in the HDF5 file, but you still need to put in
>> the DM as well
>> >   -dm_view hdf5:ex1.h5
>> >  -snes_monitor_residual hdf5:ex1.h5::append
>> >  -snes_monitor_solution hdf5:ex1.h5::append
>> >     Matt
>> > -rw-r--r--  1 markadams  staff   19760 Dec 21 13:46 res.h5
>> > -rw-r--r--  1 markadams  staff   19760 Dec 21 13:46 sol.h5
>> > but then got this. Am I doing this wrong?
>> > 13:46 multi-species *+> ~/Codes/landaufem/Plex$
>> ~/Codes/petsc/bin/petsc_gen_xdmf.py res.h5
>> > Traceback (most recent call last):
>> >   File "/Users/markadams/Codes/petsc/bin/petsc_gen_xdmf.py", line 241,
>> in <module>
>> >     generateXdmf(f)
>> >   File "/Users/markadams/Codes/petsc/bin/petsc_gen_xdmf.py", line 211,
>> in generateXdmf
>> >     geom      = h5['geometry']
>> >   File "h5py/_objects.pyx", line 54, in h5py._objects.with_phil.wrapper
>> (/Users/travis/build/MacPython/h5py-wheels/h5py/h5py/_objects.c:2405)
>> >   File "h5py/_objects.pyx", line 55, in h5py._objects.with_phil.wrapper
>> (/Users/travis/build/MacPython/h5py-wheels/h5py/h5py/_objects.c:2362)
>> >   File "/Users/markadams/homebrew/lib/python2.7/site-packages/h5py/_hl/group.py",
>> line 160, in __getitem__
>> >     oid = h5o.open(self.id, self._e(name), lapl=self._lapl)
>> >   File "h5py/h5o.pyx", line 190, in h5py.h5o.open
>> (/Users/travis/build/MacPython/h5py-wheels/h5py/h5py/h5o.c:3456)
>> > KeyError: "Unable to open object (Object 'geometry' doesn't exist)"
>> > What most experimenters take for granted before they begin their
>> experiments lead.
>> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161221/dd71d39d/attachment.html>
