[petsc-dev] snes_monitor_residual
Mark Adams mfadams at lbl.gov
Wed Dec 21 21:53:05 CST 2016
You have to add code to get dm_view to work apparently.
I have done this before. This is some hocus pocus that Toby gave me. Is
this really the way?
    PetscViewer       viewer = NULL;
    PetscBool         flg;
    PetscViewerFormat fmt;
    ierr = DMViewFromOptions(dm,NULL,"-dm_view");CHKERRQ(ierr);
    ierr =
PetscOptionsGetViewer(ctx->wComm,NULL,"-x2_vec_view",&viewer,&fmt,&flg);CHKERRQ(ierr);
    if (flg) {
      ierr = PetscViewerPushFormat(viewer,fmt);CHKERRQ(ierr);
      ierr = VecView(dmpi->phi,viewer);CHKERRQ(ierr);
      ierr = VecView(dmpi->rho,viewer);CHKERRQ(ierr);
      ierr = PetscViewerPopFormat(viewer);CHKERRQ(ierr);
   ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
On Wed, Dec 21, 2016 at 2:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   How about adding a least some documentation to bin/petsc_gen_xdmf.py
> > On Dec 21, 2016, at 1:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Wed, Dec 21, 2016 at 12:56 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > I ran with:
> > -snes_monitor_residual hdf5:res.h5
> > -snes_monitor_solution hdf5:sol.h5
> > and got h5 files that look OK:
> > That will stash vectors in the HDF5 file, but you still need to put in
> the DM as well
> >   -dm_view hdf5:ex1.h5
> >  -snes_monitor_residual hdf5:ex1.h5::append
> >  -snes_monitor_solution hdf5:ex1.h5::append
> >     Matt
> > -rw-r--r--  1 markadams  staff   19760 Dec 21 13:46 res.h5
> > -rw-r--r--  1 markadams  staff   19760 Dec 21 13:46 sol.h5
> > but then got this. Am I doing this wrong?
> > 13:46 multi-species *+> ~/Codes/landaufem/Plex$
> ~/Codes/petsc/bin/petsc_gen_xdmf.py res.h5
> > Traceback (most recent call last):
> >   File "/Users/markadams/Codes/petsc/bin/petsc_gen_xdmf.py", line 241,
> in <module>
> >     generateXdmf(f)
> >   File "/Users/markadams/Codes/petsc/bin/petsc_gen_xdmf.py", line 211,
> in generateXdmf
> >     geom      = h5['geometry']
> >   File "h5py/_objects.pyx", line 54, in h5py._objects.with_phil.wrapper
> (/Users/travis/build/MacPython/h5py-wheels/h5py/h5py/_objects.c:2405)
> >   File "h5py/_objects.pyx", line 55, in h5py._objects.with_phil.wrapper
> (/Users/travis/build/MacPython/h5py-wheels/h5py/h5py/_objects.c:2362)
> >   File "/Users/markadams/homebrew/lib/python2.7/site-packages/h5py/_hl/group.py",
> line 160, in __getitem__
> >     oid = h5o.open(self.id, self._e(name), lapl=self._lapl)
> >   File "h5py/h5o.pyx", line 190, in h5py.h5o.open (/Users/travis/build/
> MacPython/h5py-wheels/h5py/h5py/h5o.c:3456)
> > KeyError: "Unable to open object (Object 'geometry' doesn't exist)"
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161221/eb71209e/attachment.html>
