[petsc-dev] Fwd: hbw_malloc on KNL
Jeff Hammond jeff.science at gmail.com
Wed Aug 31 18:50:20 CDT 2016
Please post to https://lists.01.org/mailman/listinfo/memkind
Jeff
On Wed, Aug 31, 2016 at 3:56 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Begin forwarded message:
> *From: *Hong Zhang <hongzhang at anl.gov>
> *Subject: **hbw_malloc on KNL*
> *Date: *August 31, 2016 at 5:00:44 PM CDT
> *To: *"Smith, Barry F." <bsmith at mcs.anl.gov>, "Balay, Satish" <
> balay at mcs.anl.gov>, "Schanen, Michel" <mschanen at anl.gov>
> Hi all,
> I am experimenting with hbw_malloc() in PETSc. I used it to replace the
> default malloc() in PETSc. But I got the following error messages on the
> screen when running my PETSc example:
> map size mismatch; abort
> : No such file or directory
> Each process threw out the above message twice. After that, the program
> continued to run to the end. But it took way more time than expected.
> The good news is, if I call hbw_malloc() to allocate a bit memory, e.g. 1
> byte, before PetscInitialize(), the error will disappear and the example
> runs almost as fast as using the numactl option (which automatically put
> everything on MCDRAM). Although it works somehow, adding a test call to
> how_malloc() like this is just absurd. I am wondering if you have any clue
> on why this happens and how to fix it. FYI, I attached the driver for the
> PETSc example.
> Thanks,
> Hong
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160831/376a5549/attachment.html>
