[petsc-dev] Are there both a function AND a #define to retrieve PETSc version?
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Fri Aug 26 13:53:37 CDT 2016
wanting to prevent a possible error: I compile and link (dynamically) my
code with petsc-3.7.2 BUT I may change my LD_LIBRARY_PATH to point to
3.7.0...
I would the like my code to stop and tell me I am using the wrong libs...
I could add something like:
if (PETSC_VERSION_MAJOR != PetscInfoVersionMajor() ||
     PETSC_VERSION_MINOR != PetscInfoVersionMinor() ||
     PETSC_VERSION_PATCH != PetscInfoVersionPatch()) {
   printf("You are using a different version of PETSc than the one you
linked with...");
   exit(1);
But I then need non-inlined functions PetscInfoVersion* to have this to
work...
Does this exists?
I think It could even be into Petsc itself...
Eric
