[petsc-dev] factortype and -pc_type lu
Hong hzhang at mcs.anl.gov
Wed Aug 17 09:34:08 CDT 2016
Pierre:
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Unfactored matrix
indicates that your input matrix is an  Unfactored matrix.
If you want to replace KSPSolve() with your own MatMatSolve, you need use
following blocks
to replace KSPSolve() :
Mat F;
  ierr = KSPGetPC(ksp,&pc);
  ierr = PCFactorSetMatSolverPackage(pc,MATSOLVERPETSC);
  ierr = PCFactorSetUpMatSolverPackage(pc); /* call MatGetFactor() to
create F */
  ierr = PCFactorGetMatrix(pc,&F);
  ierr = KSPSetUp(ksp);
  ierr = MatSolve(F,b,x);
Hong
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.3-1165-gfeaa1dd  GIT
> Date: 2016-08-16 11:58:28 -0500
> Is this the expected behavior? How should I call MatSolve?
> The rationale for calling MatSolve instead of KSPSolve (for which there is
> obviously no error) is that I need to use MatMatSolve in my
> application—because there is no KSPSolve(KSP, Mat, Mat), and the behavior
> is the same for both MatSolve and MatMatSolve.
> Thank you,
> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160817/bc53ae9b/attachment.html>
