[petsc-dev] factortype and -pc_type lu
Pierre Jolivet pierre.jolivet at enseeiht.fr
Wed Aug 17 05:24:24 CDT 2016
Hello,
I slightly changed petsc/src/ksp/ksp/examples/tutorials/ex1.c by adding a simple call to MatSolve(A, b, x) before the destruction of x, b, and ksp.
If I do:
$ mpirun -np 1 ./ex1 -pc_type lu
I end up with:
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Unfactored matrix
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.3-1165-gfeaa1dd  GIT Date: 2016-08-16 11:58:28 -0500
Is this the expected behavior? How should I call MatSolve?
The rationale for calling MatSolve instead of KSPSolve (for which there is obviously no error) is that I need to use MatMatSolve in my application—because there is no KSPSolve(KSP, Mat, Mat), and the behavior is the same for both MatSolve and MatMatSolve.
Thank you,
Pierre
