[petsc-dev] git repo branches housekeeping
Mon Apr 25 12:57:03 CDT 2016
On Mon, Apr 25, 2016 at 12:01 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> ref: http://lists.mcs.anl.gov/pipermail/petsc-dev/2015-June/017808.html
> I've deleted all deveopment branches that are already merged into
> maint (v3.7) from https://bitbucket.org/petsc/petsc
> However if you wish to remove these branches from your clone - it has
> to be done manually (in each clone).
> To get this list of branches to delete - you can do:
> git branch --merged v3.7 |egrep -v " (maint|master|next)" >
> branches_to_delete
I just get
maint $:/PETSc3/petsc/petsc-dev$ git branch --merged v3.7
  knepley/feature-configuration-callbacks
which is the one branch I have leftover here. Is that what I am supposed to
get?
   Matt
> After *verifying* the list is correct - and ok to delete - they can be
> deleted with:
> git branch -d `cat branches_to_delete`
> And to sync the [deleted] remove branch list info - you can do:
> git fetch -p
> For more housekeeping - look at the remaining local and remote
> branches and figure-out what to do. [perhaps some of them are
> intermediate branches during rebase - or abandoned features that
> should be deleted]. For my branches - I would do:
> git branch
> git branch -r |grep balay
> Satish
> reference for self:
> $ git branch -r --merged v3.7 |egrep  -v origin/\(maint\|master\|next\)
> |sed -e s%origin/%:% >  remote_branches_to_delete
> $ git push -u origin `cat remote_branches_to_delete`
> To git at bitbucket.org:petsc/petsc.git
>  - [deleted]         Fande-Kong/moved-partitioning-to-pcgasmsetup
>  - [deleted]         balay-to-maint-fix-vs2015-vsnprintf
>  - [deleted]         balay/add-KSPComputeRitz-patch
>  - [deleted]         balay/add-clang-sa-build
>  - [deleted]         balay/add-fortran-DMRemoveLabel
>  - [deleted]         balay/configure-pkg-git-autoupdate
>  - [deleted]         balay/el-parmetis-check
>  - [deleted]         balay/el_AxpyInterface_removal
>  - [deleted]         balay/fix-externalpackage-build-shared
>  - [deleted]         balay/fix-fortran-unused_variables
>  - [deleted]         balay/fix-sowing-valgrind
>  - [deleted]         balay/fix-streams-npmax
>  - [deleted]         balay/fix-win-isnan
>  - [deleted]         balay/ftn-command_argument
>  - [deleted]         balay/git-externalpackage-update
>  - [deleted]         balay/improve-odpes
>  - [deleted]         balay/rm-tree
>  - [deleted]         balay/superlu_dist-4.3
>  - [deleted]         balay/superlu_dist-4.3-p1
>  - [deleted]         balay/to-maint-add-mpiuni_mpi_in_place
>  - [deleted]         balay/to-maint-add-urlretrieve-timeout
>  - [deleted]         balay/to-maint-fix-fortran-fflag-order
>  - [deleted]         balay/to-maint-fix-gfortran51-warnings
>  - [deleted]         balay/to-maint-fix-win64-long
>  - [deleted]         balay/to-maint-metis-parmetis-nocxx
>  - [deleted]         balay/to-maint-migrate-builds
>  - [deleted]         balay/to-maint/update-superlu_dist-4.1
>  - [deleted]         balay/update-elemental-0.86-pre
>  - [deleted]         balay/update-gmake-check
>  - [deleted]         balay/update-gnumake-41
>  - [deleted]         balay/update-metis-xcode-fix-to-maint
>  - [deleted]         balay/update-mpich-3.2
>  - [deleted]         balay/update-sowing-svn
>  - [deleted]         balay/update-superlu_dist_mar-16-294e2d0
>  - [deleted]         barry-allow-vecset-nan-3.6
>  - [deleted]         barry/Sylvain-gmres-symmetric
>  - [deleted]         barry/add-concurrencykit
>  - [deleted]         barry/add-dmdavecgetarrayreadf90/maint
>  - [deleted]         barry/add-dmshellcreaterestriction
>  - [deleted]         barry/add-mpiu_allreduce
>  - [deleted]         barry/add-pcfieldsplit-logevent
>  - [deleted]         barry/add-pcreset-hypre
>  - [deleted]         barry/add-pcreset-hypre-for-master
>  - [deleted]         barry/all-petscoptionssetvalue-beforepetscinitialize
>  - [deleted]         barry/always-mark-floats
>  - [deleted]         barry/better-matsetoption-error
>  - [deleted]         barry/check-for-PetscInt-overflow
>  - [deleted]         barry/check-nullspace-properties
>  - [deleted]         barry/cleanup-pcsetupcalled
>  - [deleted]         barry/cleanup-petscsys
>  - [deleted]         barry/download-mstk
>  - [deleted]         barry/download-pflowtran
>  - [deleted]         barry/downloads
>  - [deleted]         barry/error-on-extern-c-of-petscincludes
>  - [deleted]         barry/feature-force-setting-exactfinaltime
>  - [deleted]         barry/feature-linesearch-monitor
>  - [deleted]         barry/feature-ts-monitor-binary
>  - [deleted]         barry/fix-dmnetworkcomponentalignment
>  - [deleted]         barry/fix-log-summary-format
>  - [deleted]         barry/fix-matgetlocalsubmatrix
>  - [deleted]         barry/fix-matheaderreplace
>  - [deleted]         barry/fix-matseqaijgetarrayf90
>  - [deleted]         barry/fix-mg-coarse-ksp-defaults
>  - [deleted]         barry/fix-mg-coarse-redundant
>  - [deleted]         barry/fix-mpiuni
>  - [deleted]         barry/fix-mumps-destroy
>  - [deleted]         barry/fix-nonew-notcollective/maint
>  - [deleted]         barry/fix-petscviewer-attempt-2
>  - [deleted]         barry/fix-private-functions
>  - [deleted]         barry/fix-stageevent-idtypes
>  - [deleted]         barry/fix-ts-matshift-error
>  - [deleted]         barry/fix-win-e-00
>  - [deleted]         barry/fix-xsdktrilinos
>  - [deleted]         barry/fixes-for-release-1
>  - [deleted]         barry/improve-git-download
>  - [deleted]         barry/improve-minres
>  - [deleted]         barry/improve-opt-handling
>  - [deleted]         barry/improve-ts-monitor-interpolation
>  - [deleted]         barry/list-downloads
>  - [deleted]         barry/maint/fix-snessetupdate-fortran
>  - [deleted]         barry/maint/mv-matnullspace-to-mat
>  - [deleted]         barry/make-nonstatic-petscviewerflowcontrol
>  - [deleted]         barry/master/fix-cuda-extern-c
>  - [deleted]         barry/monitor-fromoptions
>  - [deleted]         barry/not-single-precision
>  - [deleted]         barry/optimize-xolotl
>  - [deleted]         barry/petscoptions-object
>  - [deleted]         barry/remove-matmffdaddnullspace/master
>  - [deleted]         barry/remove-pc-nonzero-guess
>  - [deleted]         barry/remove-pcsetup-mg-changeofpreonly/master
>  - [deleted]         barry/remove-unneed-tao-tolerances
>  - [deleted]         barry/shell-update-vector-states
>  - [deleted]         barry/simplify-test-jobs
>  - [deleted]         barry/update-hypre
>  - [deleted]         barry/update-monitors
>  - [deleted]         barry/update-petscmemoryshowusage
>  - [deleted]         barry/update-superlu
>  - [deleted]         barry/update-superlu_dist
>  - [deleted]         barry/update-superlu_dist-again
>  - [deleted]         barry/various-fixes
>  - [deleted]         barry/xml-nested-logging
>  - [deleted]         dalcinl/ts-2nd-order-systems
>  - [deleted]         dalcinl/tsbdf
>  - [deleted]         dmay/PetscSubcommDestroy-manpage
>  - [deleted]         emil/doc-add-error-control
>  - [deleted]         emil/fix-arkimex-diverged-reason
>  - [deleted]         emil/fix-manual-typos-in-ts
>  - [deleted]         emil/fix-ts-euler-generate-error-if-non-rhsfunction
>  - [deleted]         emil/to-maint-fix-euler-interpolation
>  - [deleted]         emil/to-maint-fix-ts-reporting-nonembedded
>  - [deleted]         hongzh/add-checkpointing-support-for-adaptive-ts
>  - [deleted]         hongzh/add-ts-trajectory-statistics
>  - [deleted]         hongzh/checkpointing
>  - [deleted]         hongzh/checkpointing-update
>  - [deleted]         hongzh/fix-bug-for-cost-integral
>  - [deleted]         hongzh/update-revolve
>  - [deleted]         hongzh/update-ts-trajectory
>  - [deleted]         hzhang/dmnetwork-spJacobian
>  - [deleted]         hzhang/dmnetwork-spJacobian1
>  - [deleted]         hzhang/dmnetwork-spJacobian2
>  - [deleted]         hzhang/dmnetworkmonitor
>  - [deleted]         hzhang/fix-pcredundant
>  - [deleted]         hzhang/fix-ptapfill
>  - [deleted]         hzhang/fix-superlu_dist
>  - [deleted]         hzhang/inode-erroriffpe
>  - [deleted]         hzhang/matconvert-den2el
>  - [deleted]         hzhang/matgetsubmat_sbaij1
>  - [deleted]         hzhang/matmatmult_crmax
>  - [deleted]         hzhang/matmatmult_dense
>  - [deleted]         hzhang/matpackage-erroriffpe
>  - [deleted]         hzhang/matpackage-type
>  - [deleted]         hzhang/mattransmatmult_dense
>  - [deleted]         hzhang/mumps-getseterrorflg
>  - [deleted]         hzhang/opt-ptap
>  - [deleted]         hzhang/superlu-5.1
>  - [deleted]         hzhang/superlu_dist-4.3-ex17
>  - [deleted]         hzhang/update-networkex
>  - [deleted]         hzhang/update-networkex-header
>  - [deleted]         jed/dmdarestoreelements-strict
>  - [deleted]         jed/fix-cuda-deps
>  - [deleted]         jed/fix-ksp-norm-none
>  - [deleted]         jed/fix-ml-visibility
>  - [deleted]         jed/mat-assembly-perf
>  - [deleted]         jed/process-options-handler
>  - [deleted]         jed/workaround-mpich-naughty-ibarrier
>  - [deleted]         jose/veccuda-complex
>  - [deleted]         karlrupp/feature-ViennaCL-1.7.x
>  - [deleted]         karlrupp/fix-matrixmarket-viewer
>  - [deleted]         karlrupp/fix-petscinitialize-cuda
>  - [deleted]         karpeev/fix-pcgasm-reuse
>  - [deleted]         karpeev/fix-snes-test-docs
>  - [deleted]         karpeev/maint-fix-gnupackage-ldflags
>  - [deleted]         knepley/dm-fix-header-docs
>  - [deleted]         knepley/doc-snes-ex1
>  - [deleted]         knepley/feature-dmda-add-accessors
>  - [deleted]         knepley/feature-drand48-portable
>  - [deleted]         knepley/feature-ds-copy
>  - [deleted]         knepley/feature-ex5-mms
>  - [deleted]         knepley/feature-ex5-mms-params
>  - [deleted]         knepley/feature-label-empty-stratum
>  - [deleted]         knepley/feature-mpfr
>  - [deleted]         knepley/feature-patrick-control-problem
>  - [deleted]         knepley/feature-plex-add-time
>  - [deleted]         knepley/feature-plex-handle-func-failure
>  - [deleted]         knepley/feature-plex-jacp
>  - [deleted]         knepley/feature-plex-ordering-group
>  - [deleted]         knepley/feature-plex-point-location
>  - [deleted]         knepley/feature-snes-deflation
>  - [deleted]         knepley/feature-snes-setfunctionnorm
>  - [deleted]         knepley/fix-configure-HOME
>  - [deleted]         knepley/fix-configure-compiler-log
>  - [deleted]         knepley/fix-configure-dirs
>  - [deleted]         knepley/fix-configure-logging
>  - [deleted]         knepley/fix-configure-ml
>  - [deleted]         knepley/fix-configure-relative-installdir
>  - [deleted]         knepley/fix-configure-saving
>  - [deleted]         knepley/fix-dm-clone-coord-section
>  - [deleted]         knepley/fix-dm-clone-coordinates
>  - [deleted]         knepley/fix-dt-tanhsinh
>  - [deleted]         knepley/fix-error-messages
>  - [deleted]         knepley/fix-ex5-coords-empty
>  - [deleted]         knepley/fix-ex5-patchwise
>  - [deleted]         knepley/fix-examples-plex
>  - [deleted]         knepley/fix-is-fortran
>  - [deleted]         knepley/fix-msm-opt
>  - [deleted]         knepley/fix-pc-composite-dm
>  - [deleted]         knepley/fix-pc-msm
>  - [deleted]         knepley/fix-plex-blocksize
>  - [deleted]         knepley/fix-plex-c89
>  - [deleted]         knepley/fix-plex-create-fortran
>  - [deleted]         knepley/fix-plex-distribute-label
>  - [deleted]         knepley/fix-plex-e12-3d
>  - [deleted]         knepley/fix-plex-ex1f90
>  - [deleted]         knepley/fix-plex-examples
>  - [deleted]         knepley/fix-plex-general-interp
>  - [deleted]         knepley/fix-plex-hdf5-label
>  - [deleted]         knepley/fix-plex-l2diff
>  - [deleted]         knepley/fix-plex-natural-mem
>  - [deleted]         knepley/fix-plex-point-location
>  - [deleted]         knepley/fix-plex-pragmatic-marking
>  - [deleted]         knepley/fix-plex-regression
>  - [deleted]         knepley/fix-plex-test-partitions
>  - [deleted]         knepley/fix-quadrature-test
>  - [deleted]         knepley/fix-seterrq-doc
>  - [deleted]         knepley/fix-snes-ex5-mms
>  - [deleted]         knepley/fix-snesqn-fortran
>  - [deleted]         knepley/fix-solkx
>  - [deleted]         knepley/plex-filter
>  - [deleted]         knepley/remove-pbgl
>  - [deleted]         knepley/snes-ex5-mms
>  - [deleted]         knepley/test-asm-empty-subdomain
>  - [deleted]         mark/eigen-rand
>  - [deleted]         mark/gamg-crs
>  - [deleted]         mark/gamg-rand
>  - [deleted]         mesgarnejad/feature-plex-globaltonatural
>  - [deleted]         mlange/fix-plex-fluent-reader
>  - [deleted]         mlange/fix-plex-multi-level-overlap
>  - [deleted]         pefarrell/tao-set-riesz-map
>  - [deleted]         pr263/PierreBdR/ts-domain-error-in-stage/master
>  - [deleted]         pr330/knepley/dmshell-set-create-subdm/master
>  - [deleted]         pr332/master/Fande-Kong/mat-increaseoverlap-scalable
>  - [deleted]
>  pr345/anriseth/anriseth/ngmres-reset-xm-increase/master
>  - [deleted]         pr349/mapdes/extend_hypre_boomeramg_interface/master
>  - [deleted]         pr352/dmay/pctelescope/master
>  - [deleted]         pr353/dmeiser/fix-ex2_bjacobi-update/master
>  - [deleted]         pr353/dmeiser/fix-ex2_bjacobi/master
>  - [deleted]         pr358/buptphyphy/addmatcreatenormalhermitian/master
>  - [deleted]         pr361/master/Fande-Kong/pcgasm-increaseoverlap
>  - [deleted]         pr369/Fande-Kong/fixed-comment-space/master
>  - [deleted]         pr372/vijaysm/vijaysm/moab_ts_examples_fix/master
>  - [deleted]
>  pr380/semihozmen/semihozmen/ksp-eigen-comp-bugfix/master
>  - [deleted]         pr384/Fande-Kong/fix-pcgasm-reuse/master
>  - [deleted]         pr388/mapdes/fix-petscsf-create-section-sf/master
>  - [deleted]         pr391/zianekhodja/lilia/tsirm/master
>  - [deleted]         pr394/stevengcj/blassuffix/master
>  - [deleted]         pr395/dmeiser/fix-veccuspgetarraywrite/master
>  - [deleted]         pr401/tferma/virs-pcfieldsplit-fix/master
>  - [deleted]         pr403/pascgeopc/psanan/ksp-pipe-flex/master
>  - [deleted]
>  pr404/tferma/virs-divergedlinearsolve-fix-rebase/master
>  - [deleted]         pr408/psanan/psanan/pc-bddc-view/master
>  - [deleted]
>  pr412/psanan/psanan/ksp-cg-separate-singlereduction/master
>  - [deleted]         pr413/scools/siegfriedcools/pipecgrr/master
>  - [deleted]         pr417/adam_qc/fix-tao-ls-view-typo/master
>  - [deleted]         pr421/alex/feature-veccuda
>  - [deleted]         pr426/dmay/dmay/pctelescope-mods/master
>  - [deleted]         pr428/bug-fixes-for-viennaclseqaij
>  - [deleted]         psanan/benchmarks-cleanup
>  - [deleted]         psanan/ksp-fgmres-reduce-alloc
>  - [deleted]         sanderarens/fix-plex-neumann-bc
>  - [deleted]         sarich/check-fcflags-fflags
>  - [deleted]         sarich/feature-tao-pounders-add-correlations
>  - [deleted]         sarich/fix-tao-man-objgrad
>  - [deleted]         sarich/fix-vec-stepbound
>  - [deleted]         sarich/fix-xsdk-packages
>  - [deleted]         sarich/jenkins
>  - [deleted]         shri/add-tsevent-to-powergrid-examples
>  - [deleted]
>  stefano_zampini/enable-matcreatevecs-without-preallocation
>  - [deleted]         stefano_zampini/feature-fetidp-classes
>  - [deleted]         stefano_zampini/feature-pardiso-schur
>  - [deleted]         stefano_zampini/feature-ptap-seqdense
>  - [deleted]         stefano_zampini/feature-zerorowscolumns-seqdense
>  - [deleted]         stefano_zampini/fix-for-release
>  - [deleted]         stefano_zampini/fix-static-analyzer
>  - [deleted]
>  stefano_zampini/matis-feature-localtoglobalmap-handling
>  - [deleted]         stefano_zampini/matis-fix-create
>  - [deleted]         stefano_zampini/somefixes-matdense-lda
>  - [deleted]         tisaac/buildCheck-ignore-vc-moaning
>  - [deleted]         tisaac/buildsystem-fix-pic
>  - [deleted]         tisaac/dm-label-promote
>  - [deleted]         tisaac/dm-locate-points-sf
>  - [deleted]         tisaac/dmforest
>  - [deleted]         tisaac/dmp4est-feature-injection
>  - [deleted]         tisaac/dmplex-stable-tet-refinement
>  - [deleted]         tisaac/dt-fix-geom-punning
>  - [deleted]         tisaac/fix-static-analysis-warnings
>  - [deleted]         tisaac/plex-feature-tree-fv
>  - [deleted]         tisaac/plex-fix-ex3-const
>  - [deleted]         tisaac/plex-fix-ex3-failure-message
>  - [deleted]         tisaac/plex-fix-single-prec
>  - [deleted]         tisaac/sf-fix-multi-sf-leaves
>  - [deleted]         tomklotz/feature-tanh-sinh-quadrature
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160425/eae253ea/attachment.html>
