[petsc-dev] plans for PETSc release
Sat Apr 23 10:43:03 CDT 2016
  Satish,
   Thanks
> On Apr 23, 2016, at 9:40 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Ok - the master tests ran overnight
> I've switched the day builds to maint. [nightbuilds are reverted to next]
> Also created maint-3.6 branch off maint - and updated maint with master.
> Satish
> On Fri, 22 Apr 2016, Barry Smith wrote:
>>   So the current plan is that Satish will make tonights test run on master and then tomorrow (Saturday) he will make a new maint branch off of master. At that point you should only be adding fixes to the maint branch and not new features.
>>   Thanks
>>   Barry
