[petsc-dev] plans for PETSc release
Sat Apr 23 09:40:27 CDT 2016
Ok - the master tests ran overnight
I've switched the day builds to maint. [nightbuilds are reverted to next]
Also created maint-3.6 branch off maint - and updated maint with master.
Satish
On Fri, 22 Apr 2016, Barry Smith wrote:
>    So the current plan is that Satish will make tonights test run on master and then tomorrow (Saturday) he will make a new maint branch off of master. At that point you should only be adding fixes to the maint branch and not new features.
>    Thanks
>    Barry
