[petsc-dev] --known-mpi-shared-library and --with-batch annoyance
Jed Brown jed at jedbrown.org
Thu Apr 21 22:07:59 CDT 2016
Lisandro Dalcin <dalcinl at gmail.com> writes:
>> If we allow --single-library=0, I do not see how we can avoid this.
> Shouldn't MPI static be linked only in libpetscsys? That should work...
So you want the MPI symbols to be inlined into libpetscsys.so, then
every other component that needs MPI will directly link libpetscsys.so?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160421/a873fb2d/attachment.sig>
