[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2016-04-08
Fri Apr 8 11:39:34 CDT 2016
[Checking this for Emil]
Its not clear why this warning is coming up. The following fixes
it. (not sure if its a workarround or a fix)
Any objections to pushing?
thanks,
Statish
diff --git a/src/ts/impls/explicit/rk/rk.c b/src/ts/impls/explicit/rk/rk.c
index e3d106f..dfe3de9 100644
--- a/src/ts/impls/explicit/rk/rk.c
+++ b/src/ts/impls/explicit/rk/rk.c
@@ -566,7 +566,6 @@ static PetscErrorCode TSAdjointStep_RK(TS ts)
   PetscFunctionBegin;
   t          = ts->ptime;
   rk->status = TS_STEP_INCOMPLETE;
-  h = ts->time_step;
   ierr = TSPreStep(ts);CHKERRQ(ierr);
   for (i=s-1; i>=0; i--) {
     rk->stage_time = t + h*(1.0-c[i]);
@@ -772,6 +771,7 @@ static PetscErrorCode TSSetUp_RK(TS ts)
   if (!rk->tableau) {
     ierr = TSRKSetType(ts,TSRKDefault);CHKERRQ(ierr);
+    rk = (TS_RK*)ts->data;
   tab  = rk->tableau;
   s    = tab->s;
@@ -937,6 +937,7 @@ PetscErrorCode  TSRKGetType_RK(TS ts,TSRKType *rktype)
   PetscFunctionBegin;
   if (!rk->tableau) {
   *rktype = rk->tableau->name;
   PetscFunctionReturn(0);
On Fri, 8 Apr 2016, PETSc checkBuilds wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
>   The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/f68a32c
> Implemented the renovated RK.
>   src/ts/impls/explicit/rk/rk.c:775
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-analyzer_crush.log]
>       /sandbox/petsc/petsc.clone/src/ts/impls/explicit/rk/rk.c:775:10: warning: Access to field 's' results in a dereference of a null pointer (loaded from variable 'tab')
>   src/ts/impls/explicit/rk/rk.c:939
>       /sandbox/petsc/petsc.clone/src/ts/impls/explicit/rk/rk.c:939:13: warning: Access to field 'name' results in a dereference of a null pointer (loaded from field 'tableau')
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
