[petsc-dev] [SLEPc] For users of PETSc master branch, API change
Leoni, Massimiliano Massimiliano.Leoni at Rolls-Royce.com
Mon Nov 9 08:31:00 CST 2015
Ok, sorry!
It looks like I chose the worst possible day to update :D
Best,
Massimiliano
> -----Original Message-----
> From: Jose E. Roman [mailto:jroman at dsic.upv.es]
> Sent: 09 November 2015 14:26
> To: Leoni, Massimiliano
> Cc: Barry Smith; PETSc; petsc-dev
> Subject: Re: [petsc-dev] [SLEPc] For users of PETSc master branch, API
> change
> Working on it. Be patient. Should be available on master tomorrow.
> Jose
> > El 9/11/2015, a las 15:23, Leoni, Massimiliano <Massimiliano.Leoni at Rolls-
> Royce.com> escribió:
> > Is there a branch in the SLEPc repo that supports this?
> > Massimiliano
> >> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-
> >> bounces at mcs.anl.gov] On Behalf Of Barry Smith
> >> Sent: 09 November 2015 00:21
> >> To: PETSc; petsc-dev
> >> Subject: [petsc-dev] For users of PETSc master branch, API change
> >>   For users of the PETSc master branch.
> >>   I have pushed into master some API changes for the
> >> PetscOptionsGetXXX() and related routines. The first argument is now
> >> a PetscOptions object, which is optional, if you pass a NULL in for
> >> the first argument (or a PETSC_NULL_OBJECT in Fortran) you will
> >> retain the same functionality as you had previously.
> >>   Barry
> > The data contained in, or attached to, this e-mail, may contain confidential
> information. If you have received it in error you should notify the sender
> immediately by reply e-mail, delete the message from your system and
> contact +44 (0) 3301235850 (Security Operations Centre) if you need
> assistance. Please do not copy it for any purpose, or disclose its contents to
> any other person.
> > An e-mail response to this address may be subject to interception or
> monitoring for operational reasons or for lawful business practices.
> > (c) 2015 Rolls-Royce plc
> > Registered office: 62 Buckingham Gate, London SW1E 6AT Company
> number: 1003142. Registered in England.
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
