[petsc-dev] [SLEPc] For users of PETSc master branch, API change
Jose E. Roman jroman at dsic.upv.es
Mon Nov 9 08:25:42 CST 2015
Working on it. Be patient. Should be available on master tomorrow.
Jose
> El 9/11/2015, a las 15:23, Leoni, Massimiliano <Massimiliano.Leoni at Rolls-Royce.com> escribió:
> Is there a branch in the SLEPc repo that supports this?
> Massimiliano
>> -----Original Message-----
>> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-
>> bounces at mcs.anl.gov] On Behalf Of Barry Smith
>> Sent: 09 November 2015 00:21
>> To: PETSc; petsc-dev
>> Subject: [petsc-dev] For users of PETSc master branch, API change
>>   For users of the PETSc master branch.
>>   I have pushed into master some API changes for the PetscOptionsGetXXX()
>> and related routines. The first argument is now a PetscOptions object, which
>> is optional, if you pass a NULL in for the first argument (or a
>> PETSC_NULL_OBJECT in Fortran) you will retain the same functionality as you
>> had previously.
>>   Barry
> The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
> An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
> (c) 2015 Rolls-Royce plc
> Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
