[petsc-dev] new P^1.5 algorithm in VecAssembleBegin?
Mark Adams mfadams at lbl.gov
Fri May 29 15:03:51 CDT 2015
On Fri, May 29, 2015 at 3:56 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > Yea, I realized that VecAssembly should see this load imbalance unless it
> > had a barrier before its timer.  So I'm not sure what is going on.
> Since you don't have any outgoing entries, I think the huge
> MPI_Allreduce is expensive.  No surprise.
This is on Edison and this was not a problem a few months ago.  Edison
could have changed however.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150529/b1bb9df1/attachment.html>
