[petsc-dev] new P^1.5 algorithm in VecAssembleBegin?
David Trebotich dptrebotich at lbl.gov
Fri May 29 10:44:24 CDT 2015
We won't know until 64k and 128k jobs get thru the queue.  Will keep u
posted.  Thanks for your help.
David Trebotich
sent from mobile
(510) 384-6868
On May 29, 2015 8:32 AM, "Jed Brown" <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > I don't need your branch because 1) we are not doing any communication in
> > this VecAssembly
> There is still synchronization cost in determining that nothing needs to
> be done.  Moreover, using a size P MPI_Allreduce for that (in
> PetscMaxSum) is non-scalable.  My branch uses MPI_Reduce_scatter_block
> (scalable) when available (MPI-2.2).
> > and I added the IGNORE stuff
> So it takes no time now and everything is groovy?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150529/11decd91/attachment.html>
