[petsc-dev] new P^1.5 algorithm in VecAssembleBegin?
Mark Adams mfadams at lbl.gov
Fri May 29 10:42:02 CDT 2015
On Fri, May 29, 2015 at 11:32 AM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > I don't need your branch because 1) we are not doing any communication in
> > this VecAssembly
> There is still synchronization cost in determining that nothing needs to
> be done.
I added:
VecSetOption(m_xx,VEC_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
Doesn't this remove the synchronization?
> Moreover, using a size P MPI_Allreduce for that (in
> PetscMaxSum) is non-scalable.  My branch uses MPI_Reduce_scatter_block
> (scalable) when available (MPI-2.2).
> > and I added the IGNORE stuff
> So it takes no time now and everything is groovy?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150529/eb43117d/attachment.html>
