[petsc-dev] PetscSF vs VecScatter
Blaise A Bourdin bourdin at lsu.edu
Thu May 21 15:16:48 CDT 2015
What is PETSc’s vision for VecScatter and PetscSF?
It seems that the only thing that prevents PetscSF from completely replacing VecScatter right now is that it does not support operations (ADD_VALUES, INSERT_VALUES). Is this an inherent restriction to SF that will force it to coexists with VecScatter, or is there a plan to add support for operations and gradually replace VecScatter with PetscSF?
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
