[petsc-dev] Errors when testing PETSc build on Windows
Hector E Barrios Molano hectorb at utexas.edu
Wed Jun 17 15:57:48 CDT 2015
Hi Satish,
Taking out --with-sowing=0 gives me:
$ ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
--prefix=/cygdrive/c/Installed/petsc/ --PETSC_ARCH=windows-intel
--with-parmetis-include=/cygdrive/c/Installed/parmetis/include
--with-parmetis-lib=/cygdrive/c/Installed/parmetis/lib/parmetis.lib
--with-metis-include=/cygdrive/c/Installed/parmetis/include
--with-metis-lib=/cygdrive/c/Installed/parmetis/lib/metis.lib
--with-mpi-include=[/cygdrive/c/Installed/msmpi/Include,/cygdrive/c/Installed/msmpi/Include/x64]
--with-mpi-lib=[/cygdrive/c/Installed/msmpi/Lib/x64/msmpi.lib,/cygdrive/c/Installed/msmpi/Lib/x64/msmpifec.lib]
--with-blas-lapack-lib=[/cygdrive/c/Installed/mkl/lib/intel64/mkl_intel_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_sequential.lib]
--with-scalapack-include=/cygdrive/c/Installed/mkl/include
--with-scalapack-lib=[/cygdrive/c/Installed/mkl/lib/intel64/mkl_scalapack_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_blacs_msmpi_lp64.lib]
             Configuring PETSc to compile on your system
                                                  *****WARNING:
PETSC_DIR appears to be a Git clone - but git is not found in
PATH********
                                                           Trying to
download http://ftp.mcs.anl.gov/pub/petsc/externalpackages/sowing-1.1.17-p1.tar.gz
for SOWING
                                                           Trying to
download ftp://ftp.mcs.anl.gov/pub/petsc/externalpackages/sowing-1.1.17-p1.tar.gz
for SOWING
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
Error changing permissions for sowing-1.1.17-p1 obtained from
/cygdrive/c/Installed/petsc-dev/petsc/windows-intel/externalpackages/_d_sowing-1.1.17-p1.tar.gz
: Could not execute "cd
/cygdrive/c/Installed/petsc-dev/petsc/windows-intel/externalpackages;
chmod -R a+r sowing-1.1.17-p1;find  sowing-1.1.17-p1 -type d -name "*"
-exec chmod a+rx {} \;":
FIND: Parameter format not correct
On Wed, Jun 17, 2015 at 3:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> --with-sowing=0
> 1. make sure you have cygwin gcc/g++ installed.
> 2. configure PETSc without the above option [and rebuild the libraries]
> Satish
> On Wed, 17 Jun 2015, Hector E Barrios Molano wrote:
>> Hi Satish,
>> Thank you! It solved some errors. However, I'm still having problems
>> with the Fortran test.
>> $ make PETSC_DIR=/cygdrive/c/Installed/petsc-dev/petsc
>> PETSC_ARCH=windows-intel test
>> Running test examples to verify correct installation
>> Using PETSC_DIR=/cygdrive/c/Installed/petsc-dev/petsc and
>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
>> MPI process
>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
>> MPI processes
>> *******************Error detected during compile or link!*******************
>> See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> /cygdrive/c/Installed/petsc-dev/petsc/src/snes/examples/tutorials ex5f
>> /cygdrive/c/Installed/petsc-dev/petsc/bin/win32fe/win32fe ifort -c
>> -MT -Z7 -fpp  -I/cygdrive/c/Installed/petsc-dev/petsc/include
>> -I/cygdrive/c/Installed/petsc-dev/petsc/windows-intel/include
>> -I/cygdrive/c/Installed/parmetis/include
>> -I/cygdrive/c/Installed/msmpi/Include
>> -I/cygdrive/c/Installed/msmpi/Include/x64    -o ex5f.o ex5f.F
>> /cygdrive/c/Installed/petsc-dev/petsc/bin/win32fe/win32fe ifort -MT
>> -Z7 -fpp  -o ex5f ex5f.o
>> -L/cygdrive/c/Installed/petsc-dev/petsc/windows-intel/lib  -lpetsc
>> /cygdrive/c/Installed/msmpi/Lib/x64/msmpifec.lib Gdi32.lib User32.lib
>> Advapi32.lib Kernel32.lib Ws2_32.lib
>> ex5f.obj : error LNK2019: unresolved external symbol SNESCREATE
>> referenced in function MAIN__
>> DMCREATEGLOBALVECTOR referenced in function MAIN__
>> ex5f.obj : error LNK2019: unresolved external symbol VECDUPLICATE
>> ex5f.obj : error LNK2019: unresolved external symbol DMDAGETCORNERS
>> DMDAGETGHOSTCORNERS referenced in function MAIN__
>> ex5f.obj : error LNK2019: unresolved external symbol SNESSETDM
>> SNESSETFROMOPTIONS referenced in function MAIN__
>> SNESGETITERATIONNUMBER referenced in function MAIN__
>> ex5f.obj : error LNK2019: unresolved external symbol VECDESTROY
>> ex5f.obj : error LNK2019: unresolved external symbol SNESDESTROY
>> ex5f.obj : error LNK2019: unresolved external symbol DMDESTROY
>> ex5f.obj : error LNK2019: unresolved external symbol MATSETVALUESLOCAL
>> referenced in function FORMJACOBIANLOCAL
>> ex5f.obj : error LNK2019: unresolved external symbol MATASSEMBLYBEGIN
>> ex5f.obj : error LNK2019: unresolved external symbol MATASSEMBLYEND
>> C:\INSTAL~1\PETSC-~1\petsc\src\snes\examples\TUTORI~1\ex5f.exe : fatal
>> error LNK1120: 14 unresolved externals
>> makefile:50: recipe for target 'ex5f' failed
>> make[3]: [ex5f] Error 96 (ignored)
>> /usr/bin/rm -f ex5f.o
>> Completed test examples
>> Now to evaluate the computer systems you plan use - do:
>> PETSC_ARCH=windows-intel streams NPMAX=<number of MPI processes you
>> intend to use>
>> On Wed, Jun 17, 2015 at 3:01 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > /cygdrive/c/Installed/mkl/lib/intel64/mkl_intel_ilp64.lib
>> > This is the wrong version of MKL. You should look for lp64 variant [not ilp64]
>> > [you can just edit PETSC_DIR/PETSC_ARCH/lib/petsc/conf/petscvariables and make this
>> > change manually - and retry compiling the example]
>> > Satish
>> >> Hi PETSc Experts!
>> >> I'm trying to build PETSc on a Windows machine, I got errors during
>> >> the test part. I downloaded petsc-dev from git.
>> >> This are my configuration command:
>> >> --with-blas-lapack-lib=[/cygdrive/c/Installed/mkl/lib/intel64/mkl_intel_ilp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_sequential.lib]
>> >> --with-scalapack-lib=[/cygdrive/c/Installed/mkl/lib/intel64/mkl_scalapack_ilp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_blacs_msmpi_ilp64.lib]
>> >> --with-sowing=0
>> >> I was able con configure and compile:
>> >> PETSC_ARCH=windows-intel all
>> >> However, when testing I got these errors:
>> >> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
>> >> lid velocity = 0.0016, prandtl # = 1, grashof # = 1
>> >> [0]PETSC ERROR:
>> >> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> >> probably memory access out of range
>> >> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> >> [0]PETSC ERROR: or see
>> >> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> >> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>> >> OS X to find memory corruption errors
>> >> [0]PETSC ERROR: likely location of problem given in stack below
>> >> [0]PETSC ERROR: ---------------------  Stack Frames
>> >> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>> >> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>> >> [0]PETSC ERROR:       is given.
>> >> [0]PETSC ERROR: [0] VecNorm_Seq line 240
>> >> C:\INSTAL~1\PETSC-~1\petsc\src\vec\vec\impls\seq\bvec2.c
>> >> [0]PETSC ERROR: [0] VecNorm line 228
>> >> C:\INSTAL~1\PETSC-~1\petsc\src\vec\vec\INTERF~1\rvector.c
>> >> [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 150
>> >> C:\INSTAL~1\PETSC-~1\petsc\src\snes\impls\ls\ls.c
>> >> [0]PETSC ERROR: [0] SNESSolve line 3847
>> >> C:\INSTAL~1\PETSC-~1\petsc\src\snes\INTERF~1\snes.c
>> >> [0]PETSC ERROR: [0] main line 108
>> >> C:\INSTAL~1\PETSC-~1\petsc\src\snes\examples\TUTORI~1\ex19.c
>> >> [0]PETSC ERROR: --------------------- Error Message
>> >> [0]PETSC ERROR: Signal received
>> >> [0]PETSC ERROR: See
>> >> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> >> shooting.
>> >> [0]PETSC ERROR: Petsc Development GIT revision: unknown  GIT Date: unknown
>> >> [0]PETSC ERROR: ./ex19 on a windows-intel named HECTOR-PC by hector
>> >> Wed Jun 17 14:21:38 2015
>> >> [0]PETSC ERROR: Configure options --with-cc="win32fe cl"
>> >> --with-fc="win32fe ifort" --prefix=/cygdrive/c/Installed/petsc/
>> >> --with-mpi-include="[/cygdrive/c/Installed/msmpi/Include,/cygdrive/c/Installed/msmpi/Include/x64]"
>> >> --with-mpi-lib="[/cygdrive/c/Installed/msmpi/Lib/x64/msmpi.lib,/cygdrive/c/Installed/msmpi/Lib/x64/msmpifec.lib]"
>> >> --with-blas-lapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_intel_ilp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_sequential.lib]"
>> >> --with-scalapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_scalapack_ilp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_blacs_msmpi_ilp64.lib]"
>> >> --with-sowing=0
>> >> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>> >> job aborted:
>> >> [ranks] message
>> >> [0] application aborted
>> >> aborting MPI_COMM_WORLD (comm=0x44000000), error 59, comm rank 0
>> >> ---- error analysis -----
>> >> [0] on hector-PC
>> >> ./ex19 aborted the job. abort code 59
>> >> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2
>> >> MPI processes
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> Caught signal number 11 SEGV: Segmentation Violation, probably memory
>> >> access out of range
>> >> access out of range
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> or try http://valgrind.org on GNU/linux and Apple Mac OS X to find
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> ---------------------  Stack Frames ------------------------------------
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >>       is given.
>> >>       is given.
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0] VecNorm_MPI line 57 C:\INSTAL~1\PETSC-~1\petsc\src\vec\vec\impls\mpi\pvec2.c
>> >> [1] VecNorm_MPI line 57 C:\INSTAL~1\PETSC-~1\petsc\src\vec\vec\impls\mpi\pvec2.c
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0] VecNorm line 228 C:\INSTAL~1\PETSC-~1\petsc\src\vec\vec\INTERF~1\rvector.c
>> >> [1] VecNorm line 228 C:\INSTAL~1\PETSC-~1\petsc\src\vec\vec\INTERF~1\rvector.c
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [1] SNESSolve_NEWTONLS line 150
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0] SNESSolve line 3847 C:\INSTAL~1\PETSC-~1\petsc\src\snes\INTERF~1\snes.c
>> >> [1] SNESSolve line 3847 C:\INSTAL~1\PETSC-~1\petsc\src\snes\INTERF~1\snes.c
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0] main line 108 C:\INSTAL~1\PETSC-~1\petsc\src\snes\examples\TUTORI~1\ex19.c
>> >> [1] main line 108 C:\INSTAL~1\PETSC-~1\petsc\src\snes\examples\TUTORI~1\ex19.c
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> Signal received
>> >> Signal received
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> ./ex19 on a windows-intel named HECTOR-PC by hector Wed Jun 17 14:21:38 2015
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> Configure options --with-cc="win32fe cl" --with-fc="win32fe ifort"
>> >> --with-sowing=0
>> >> --with-sowing=0
>> >> [0]PETSC ERROR:
>> >> [1]PETSC ERROR:
>> >> job aborted:
>> >> [ranks] message
>> >> [1] application aborted
>> >> aborting MPI_COMM_WORLD (comm=0x44000000), error 59, comm rank 1
>> >> [0-1] on hector-PC
>> >> intend to use>
>> >> Best Regards,
>> >> Hector
