[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2015-06-16
Fande Kong fdkong.jd at gmail.com
Wed Jun 17 11:42:45 CDT 2015
Hi Satish,
I used the configure at
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log,
and the code looks fine and do not have any warnings and errors.
Fande Kong,
On Tue, Jun 16, 2015 at 9:28 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Which ones are you trying to reproduce? Some of the solaris warnings
> might not show up on linux..
> Satish
> /On Tue, 16 Jun 2015, Fande Kong wrote:
> > Hi Karl,
> > Thanks for your suggestions. I am using GCC-4.8.1. I will try GCC 4.6.x
> to
> > see if I get anythings.
> > Fande Kong,
> > On Tue, Jun 16, 2015 at 4:04 PM, Karl Rupp <rupp at iue.tuwien.ac.at>
> wrote:
> > > Hi Fande,
> > > the respective configure log states that GCC 4.6.3 was used. Have you
> > > tried to compile using GCC 4.6.x? You might have it available as an
> > > alternative in your package manager.
> > > Did you check whether the flags
> > > -std=c89 -pedantic -Wno-long-long -Wno-overlength-strings -fPIC -g3 -O0
> > > show up in your build as well?
> > > Best regards,
> > > Karli
> > > On 06/16/2015 11:29 PM, Fande Kong wrote:
> > >> To whom it may concern,
> > >> I was wondering there are any easy ways to reproduce these warnings
> and
> > >> errors. I did reconfigure my local branch according to the log files
> at
> > >> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive. I found some
> > >> warnings and errors and fixed them, but there are still a few warnings
> > >> and errors I could not reproduce so that I could not fix them.
> > >> Any suggestions?
> > >> Fande Kong
> > >> On Tue, Jun 16, 2015 at 8:00 AM, PETSc checkBuilds
> > >> <petsc-checkbuilds at mcs.anl.gov <mailto:petsc-checkbuilds at mcs.anl.gov
> > >> wrote:
> > >>     Dear PETSc developer,
> > >>     This email contains listings of contributions attributed to you by
> > >>     `git blame` that caused compiler errors or warnings in PETSc
> automated
> > >>     testing.  Follow the links to see the full log files. Please
> attempt
> > >>     to fix
> > >>     the issues promptly or let us know at petsc-dev at mcs.anl.gov
> > >>     <mailto:petsc-dev at mcs.anl.gov> if you are unable
> > >>     to resolve the issues.
> > >>     Thanks,
> > >>        The PETSc development team
> > >>     warnings attributed to commit
> > >>     https://bitbucket.org/petsc/petsc/commits/086af2c
> > >>     changed 'hierarchpart' to 'hierarchical'
> > >>        src/mat/partition/impls/hierarchical/hierarchical.c:150
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-linux-c89_thrash.log
> /sandbox/petsc/petsc.clone-2/src/mat/partition/impls/hierarchical/hierarchical.c:150:3:
> > >>     warning: ISO C90 forbids mixed declarations and code [-Wpedantic]
> > >>     https://bitbucket.org/petsc/petsc/commits/5495542
> > >>     implemented MatGetSubMatrices_MPIAdj
> > >>        src/mat/impls/adj/mpi/mpiadj.c:575
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-linux-opt-cxx-quad_cg.log
> > >>     /sandbox/petsc/petsc.clone/src/mat/impls/adj/mpi/mpiadj.c:575:35:
> > >>     warning: 'rlocalindex' may be used uninitialized in this function
> > >>     [-Wmaybe-uninitialized]
> > >>     https://bitbucket.org/petsc/petsc/commits/54b07c2
> > >>     implemented ISBuildTwoSided
> > >>        src/vec/is/is/utils/iscoloring.c:416
>  /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:416:11:
> > >> error:
> > >>     no matching function for call to 'PetscCommBuildTwoSided'
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-opensolaris-misc_n-gage.log
>  "/export/home/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c",
> > >>     line 416: warning: argument #7 is incompatible with prototype:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-linux-pkgs-64idx_thrash.log
>  /sandbox/petsc/petsc.clone-3/src/vec/is/is/utils/iscoloring.c:416:11:
> > >> warning:
> > >>     passing argument 7 of 'PetscCommBuildTwoSided' from incompatible
> > >>     pointer type
> > >>        src/vec/is/is/utils/iscoloring.c:444
>  /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:444:41:
> > >> warning:
> > >>     argument type 'PetscInt *' (aka 'long *') doesn't match specified
> > >>     'MPI' type tag that requires 'long long *' [-Wtype-safety]
>  /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:444:54:
> > >> warning:
> > >>        src/vec/is/is/utils/iscoloring.c:445
>  /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:445:52:
> > >> warning:
>  /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:445:39:
> > >> warning:
> > >>     https://bitbucket.org/petsc/petsc/commits/77fca31
> > >>     add runex40_2
> > >>        src/mat/examples/tests/ex40.c:22
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/examples_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
> > >>     /sandbox/petsc/petsc.clone-2/src/mat/examples/tests/ex40.c:22:18:
> > >>     warning: unused variable 'rmap' [-Wunused-variable]
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/examples_next_arch-linux-gcc-ifc-cmplx_crank.log
> > >>     https://bitbucket.org/petsc/petsc/commits/841d17a
> > >>     implemented a MatGetSubMatrix_MPIAdj_Single
> > >>        src/mat/impls/adj/mpi/mpiadj.c:574
> > >>     /sandbox/petsc/petsc.clone/src/mat/impls/adj/mpi/mpiadj.c:574:29:
> > >>     warning: 'owner' may be used uninitialized in this function
> > >>     https://bitbucket.org/petsc/petsc/commits/9d01615
> > >>     Rewrite an implementation of matincreaseoverlap
> > >>        src/mat/impls/aij/mpi/mpiov.c:134
> > >>     "/export/home/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c",
> > >>     line 134: warning: argument #7 is incompatible with prototype:
> > >>     /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:134:10:
> > >>     warning: passing argument 7 of 'PetscCommBuildTwoSided' from
> > >>     incompatible pointer type
> > >>        src/mat/impls/aij/mpi/mpiov.c:170
> > >>     line 170: warning: argument #7 is incompatible with prototype:
> > >>     /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:170:10:
> > >>     To opt-out from receiving these messages - send a request to
> > >>     petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150617/70225ffd/attachment.html>
