[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2015-06-16
Tue Jun 16 22:28:44 CDT 2015
Which ones are you trying to reproduce? Some of the solaris warnings
might not show up on linux..
Satish
/On Tue, 16 Jun 2015, Fande Kong wrote:
> Hi Karl,
> Thanks for your suggestions. I am using GCC-4.8.1. I will try GCC 4.6.x to
> see if I get anythings.
> Fande Kong,
> On Tue, Jun 16, 2015 at 4:04 PM, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> > Hi Fande,
> > the respective configure log states that GCC 4.6.3 was used. Have you
> > tried to compile using GCC 4.6.x? You might have it available as an
> > alternative in your package manager.
> > Did you check whether the flags
> > -std=c89 -pedantic -Wno-long-long -Wno-overlength-strings -fPIC -g3 -O0
> > show up in your build as well?
> > Best regards,
> > Karli
> > On 06/16/2015 11:29 PM, Fande Kong wrote:
> >> To whom it may concern,
> >> I was wondering there are any easy ways to reproduce these warnings and
> >> errors. I did reconfigure my local branch according to the log files at
> >> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive. I found some
> >> warnings and errors and fixed them, but there are still a few warnings
> >> and errors I could not reproduce so that I could not fix them.
> >> Any suggestions?
> >> Fande Kong
> >> On Tue, Jun 16, 2015 at 8:00 AM, PETSc checkBuilds
> >> <petsc-checkbuilds at mcs.anl.gov <mailto:petsc-checkbuilds at mcs.anl.gov>>
> >> wrote:
> >>     Dear PETSc developer,
> >>     This email contains listings of contributions attributed to you by
> >>     `git blame` that caused compiler errors or warnings in PETSc automated
> >>     testing.  Follow the links to see the full log files. Please attempt
> >>     to fix
> >>     the issues promptly or let us know at petsc-dev at mcs.anl.gov
> >>     <mailto:petsc-dev at mcs.anl.gov> if you are unable
> >>     to resolve the issues.
> >>     Thanks,
> >>        The PETSc development team
> >>     warnings attributed to commit
> >>     https://bitbucket.org/petsc/petsc/commits/086af2c
> >>     changed 'hierarchpart' to 'hierarchical'
> >>        src/mat/partition/impls/hierarchical/hierarchical.c:150
> >> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-linux-c89_thrash.log
> >> /sandbox/petsc/petsc.clone-2/src/mat/partition/impls/hierarchical/hierarchical.c:150:3:
> >>     warning: ISO C90 forbids mixed declarations and code [-Wpedantic]
> >>     https://bitbucket.org/petsc/petsc/commits/5495542
> >>     implemented MatGetSubMatrices_MPIAdj
> >>        src/mat/impls/adj/mpi/mpiadj.c:575
> >> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-linux-opt-cxx-quad_cg.log
> >>     /sandbox/petsc/petsc.clone/src/mat/impls/adj/mpi/mpiadj.c:575:35:
> >>     warning: 'rlocalindex' may be used uninitialized in this function
> >>     [-Wmaybe-uninitialized]
> >>     https://bitbucket.org/petsc/petsc/commits/54b07c2
> >>     implemented ISBuildTwoSided
> >>        src/vec/is/is/utils/iscoloring.c:416
> >> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
> >>     /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:416:11:
> >> error:
> >>     no matching function for call to 'PetscCommBuildTwoSided'
> >> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-opensolaris-misc_n-gage.log
> >>     "/export/home/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c",
> >>     line 416: warning: argument #7 is incompatible with prototype:
> >> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/build_next_arch-linux-pkgs-64idx_thrash.log
> >>     /sandbox/petsc/petsc.clone-3/src/vec/is/is/utils/iscoloring.c:416:11:
> >> warning:
> >>     passing argument 7 of 'PetscCommBuildTwoSided' from incompatible
> >>     pointer type
> >>        src/vec/is/is/utils/iscoloring.c:444
> >>     /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:444:41:
> >> warning:
> >>     argument type 'PetscInt *' (aka 'long *') doesn't match specified
> >>     'MPI' type tag that requires 'long long *' [-Wtype-safety]
> >>     /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:444:54:
> >> warning:
> >>        src/vec/is/is/utils/iscoloring.c:445
> >>     /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:445:52:
> >> warning:
> >>     /sandbox/petsc/petsc.clone-2/src/vec/is/is/utils/iscoloring.c:445:39:
> >> warning:
> >>     https://bitbucket.org/petsc/petsc/commits/77fca31
> >>     add runex40_2
> >>        src/mat/examples/tests/ex40.c:22
> >> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/examples_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
> >>     /sandbox/petsc/petsc.clone-2/src/mat/examples/tests/ex40.c:22:18:
> >>     warning: unused variable 'rmap' [-Wunused-variable]
> >> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/16/examples_next_arch-linux-gcc-ifc-cmplx_crank.log
> >>     https://bitbucket.org/petsc/petsc/commits/841d17a
> >>     implemented a MatGetSubMatrix_MPIAdj_Single
> >>        src/mat/impls/adj/mpi/mpiadj.c:574
> >>     /sandbox/petsc/petsc.clone/src/mat/impls/adj/mpi/mpiadj.c:574:29:
> >>     warning: 'owner' may be used uninitialized in this function
> >>     https://bitbucket.org/petsc/petsc/commits/9d01615
> >>     Rewrite an implementation of matincreaseoverlap
> >>        src/mat/impls/aij/mpi/mpiov.c:134
> >>     "/export/home/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c",
> >>     line 134: warning: argument #7 is incompatible with prototype:
> >>     /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:134:10:
> >>     warning: passing argument 7 of 'PetscCommBuildTwoSided' from
> >>     incompatible pointer type
> >>        src/mat/impls/aij/mpi/mpiov.c:170
> >>     line 170: warning: argument #7 is incompatible with prototype:
> >>     /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:170:10:
> >>     To opt-out from receiving these messages - send a request to
> >>     petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>.
