[petsc-dev] ML via --download-ml
Fri Jun 12 06:38:26 CDT 2015
On Fri, Jun 12, 2015 at 6:24 AM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> I've noticed very different performance with ML when I (a) link PETSc
> to a Trilinos installation; or (b) use --download-ml. I observe
> - Case (a): solver behaves exactly as I would expect. Iteration counts
> very close to GAMG iteration counts, minimal dependency on problem
> size.
> - Case (b): iteration counts higher and substantial increase in
> iteration count with problem size.
> I haven't debugged since I usually link to Trilinos, in which case
> performance is as I expect.
ML stopped being distributed independent of Trilinos a while ago, so we
might not
have upstream changes. This sounds like a difference of settings. The first
step I think
is to look at -ksp_view for both runs.
     Matt
> Garth
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150612/c6d80d54/attachment.html>
