[petsc-dev] ML via --download-ml
Garth N. Wells gnw20 at cam.ac.uk
Fri Jun 12 06:24:09 CDT 2015
I've noticed very different performance with ML when I (a) link PETSc
to a Trilinos installation; or (b) use --download-ml. I observe
- Case (a): solver behaves exactly as I would expect. Iteration counts
very close to GAMG iteration counts, minimal dependency on problem
size.
- Case (b): iteration counts higher and substantial increase in
iteration count with problem size.
I haven't debugged since I usually link to Trilinos, in which case
performance is as I expect.
Garth
