[petsc-dev] Adding support memkind allocators in PETSc
Richard Mills rtm at utk.edu
Wed Jun 3 20:55:08 CDT 2015
Ha, yes.  I'll try this out, but I do wonder what people's thoughts are on
the best way to "tag" an object like a Vec or Mat for some particular
treatment of its placement in memory.  Does doing this at the level of a
Mat or Vec (e.g., VecSetAdvMallocCtx() ) sound appropriate?  We could
actually make this a part of any PetscObject, but I think that's not
necessary.
--Richard
On Wed, Jun 3, 2015 at 6:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   The beauty of git/bitbucket is one can make branches to try out anything
> they want even if some cranky old conservative PETSc developer thinks it is
> worse then consorting with the devil.
>    As I said before I think that "additional argument" to advised_malloc
> should be a living object which one can change over time as opposed to just
> a "flag" type argument that only effects the malloc at malloc time. Of
> course the "living part" can be implemented later.
>    Barry
> Yes, Jed has already transformed himself into a cranky old conservative
> PETSc developer
> > On Jun 3, 2015, at 7:33 PM, Richard Mills <rtm at utk.edu> wrote:
> > Hi Folks,
> > It's been a while, but I'd like to pick up this discussion of adding a
> context to memory allocations again.
> > The immediate motivation I have is that I'd like to support use of the
> memkind library (https://github.com/memkind/memkind), though adding a
> context to PetscMallocN() (or making some other interface, say
> PetscAdvMalloc() or whatever) could have much broader utility than simply
> memkind support (which Jed doesn't like anyway, and I share some of his
> concerns).  For the sake of having a concrete example, I'll discuss memkind
> here.
> > Memkind's memkind_malloc() works like malloc() but takes a memkind_t
> argument to specify some desired property of the memory being allocated.
> For example,
> >  hugetlb_str = (char *)memkind_malloc(MEMKIND_HUGETLB, size);
> > returns a pointer to memory allocated using huge pages, and
> >  hbw_preferred_str = (char *)memkind_malloc(MEMKIND_HBW_PREFERRED, size);
> > allocates memory from a high-bandwidth region if it's available and
> elsewhere if not (specifying MEMKIND_HBW will insist on the allocation
> coming from high-bandwidth memory, failing if it's not available).
> > It should be straightforward to add a variant of PetscMalloc() that
> accepts a context: I'll call this PetscAdvMalloc(), for now, though we can
> come up with a better name later.  This will allow passing on the memkind_t
> via this context to the underlying memkind allocator, and we can have some
> mechanism to set a default context (in the case of Memkind, this is likely
> MEMKIND_DEFAULT) that gets used when plain PetscMalloc() gets called.
> > Of course, we'll need some way to ensure that the "advanced malloc" gets
> used to allocated the critical data structures.  As a low-level way to
> start, it may make sense to simply add a way to stash a context in Vec and
> Mat objects.  Maybe have VecSetAdvMallocCtx(), and if that context gets
> set, then PetscAdvMalloc() is used for the allocations associated with the
> contents of that object.  It would probably be better to eventually have a
> higher-level way to do this, e.g., support standard settings in the options
> database that PETSc uses to construct the appropriate arguments to
> underlying allocators that are supported, but I think just adding a way to
> set this context directly is an appropriate first step.
> > Does this sound like a reasonable thing for me to prototype, or are
> others thinking something very different?  Please let me know.  I'm getting
> more access to early systems I can experiment on, and I'd really like to
> move forward on trying things with high bandwidth memory (imperfect as our
> APIs for using it are).
> > Best regards,
> > Richard
> > On Wed, Apr 29, 2015 at 11:10 PM, Richard Mills <rtm at utk.edu> wrote:
> > On Wed, Apr 29, 2015 at 1:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Forget about the issue of "changing" PetscMallocN() or adding a new
> interface instead, that is a minor syntax and annoyance issue:
> >   The question is "is it worth exploring adding a context for certain
> memory allocations that would allow us to "do" various things to the memory
> and "indicate" properties of the memory"? I think, though I agree with Jed
> that it could be fraught with difficulties, that is is worthwhile playing
> around with this.
> >   Barry
> > I vote "yes".  One might want to, say
> > * Give hints via something like madvise() on how/when the memory might
> be accessed.
> > * Specify a preferred "kind" of memory (and behavior if the preferred
> kind is not available, or perhaps even specify a priority on how hard to
> try to get the preferred memory kind)
> > * Specify something like a preference to interleave allocation blocks
> between different kinds of memory
> > I'm sure we can come up with plenty of other possibilities, some of
> which might actually be useful, many of which will be useful only for very
> contrived cases, and some that are not useful today but may become useful
> as memory systems evolve.
> > --Richard
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150603/4094237d/attachment.html>
