[petsc-dev] -mat_error_if_fpe?
Tue Jun 2 15:58:46 CDT 2015
> On Jun 2, 2015, at 3:29 PM, Dmitry Karpeyev <karpeev at mcs.anl.gov> wrote:
> Currently -pc_type lu will not detect a zero pivot (it will happily produce an Inf or a NaN) and the flag it checks whether to see whether
> to do it is erroriffpe.   KSP_DIVERGED_NANORINF is too generic.  What if the user wants to verify there is a zero pivot?
   -ksp_error_if_not_converged will cause an immediate stack trace when the zero pivot occurs (as would the user calling MatSetErrorIfFPE() on the matrix or the use of -mat_error_if_fpe if it existed).
   There is no way currently to get back programatically anything more specific than KSP_DIVERGED_NANORINF on a zero pivot, we can start adding more that has nothing to do with -mat_error_if_fpe
> Also, irrespective of the use case, if we have a XXXSetYYY(), isn't our policy to have a command-line way of doing it?
  No, only when it makes sense and doesn't duplicate other functionality. I don't see -mat_error_if_fpe in this case adding anything more helpful then the already existing -ksp_error_if_not_converged
  Convince me.
  Barry
> On Tue, Jun 2, 2015 at 2:21 PM Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jun 2, 2015, at 3:02 PM, Dmitry Karpeyev <karpeev at mcs.anl.gov> wrote:
> > Should we have a way to turn on/off MatErrorIfFPE() on the command line?
>   Sure, one does it with -ksp_error_if_not_converged or -snes_error_if_not_converged  It only adds to user confusion, but no user benefit, to have a -mat_error_if_fpe thing.
>   What user case do think there is for a -mat_error_if_fpe ?
>   Barry
> > It is now turned off by default to allow Inf/NaNs to propagate and currently the only way to toggle it is programmatic.
> > Dmitry.
