[petsc-dev] [petsc-checkbuilds] PETSc blame digest (master) 2015-06-01
Jed Brown jed at jedbrown.org
Mon Jun 1 23:38:54 CDT 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Jed,
>    What the fuck is this doing in master?
It is not in 'master'.
$ git branch -r --contains 4b4eb8d
  bb/jed/mat-assembly-perf
  bb/next
Is something wrong with the script?
>    It has sent email for weeks and weeks from next with this exact
>    warning message and should never have been moved over to master
>    until the error was fixed.  It is inexcusable that this problem got
>    moved into master after it was broken so long in next and never
>    fixed.
As far as I can tell, these are only warnings and only appear with C++
when using some particular compiler versions.  I figured that was an
excuse for "not urgent", but I realize it's been entirely too long.  I
found a compiler that could reproduce the warning and have fixed it in
'next'.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150602/db496a5f/attachment.sig>
