[petsc-dev] [petsc-checkbuilds] PETSc blame digest (master) 2015-06-01
Mon Jun 1 21:08:14 CDT 2015
  Jed,
   What the fuck is this doing in master? It has sent email for weeks and weeks from next with this exact warning message and should never have been moved over to master until the error was fixed.  It is inexcusable that this problem got moved into master after it was broken so long in next and never fixed.
Barry
> On Jun 1, 2015, at 9:00 PM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
>  The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/4b4eb8d
> MatAssembly: move check for InsertMode consistency into MatStashScatter impls
>  src/mat/utils/matstash.c:945
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/01/build_master_arch-linux-gcc-absoft_churn.log]
>      /sandbox/petsc/petsc.clone/src/mat/utils/matstash.c:945:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/01/build_master_arch-linux-opt-cxx-quad_cg.log]
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/06/01/build_master_arch-freebsd-cxx-pkgs-opt_wii.log]
>      /usr/home/balay/petsc.clone-2/src/mat/utils/matstash.c:945: warning: comparison between signed and unsigned integer expressions
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/97da894
> MatStash BTS: add MAT_SUBSET_OFF_PROC_ENTRIES, impl with neighbor-only comm
>  src/mat/utils/matstash.c:894
>      /sandbox/petsc/petsc.clone/src/mat/utils/matstash.c:894:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>      /usr/home/balay/petsc.clone-2/src/mat/utils/matstash.c:894: warning: comparison between signed and unsigned integer expressions
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/d7d6084
> MatStash: initial BTS (BuildTwoSided) implementation
>  src/mat/utils/matstash.c:906
>      /sandbox/petsc/petsc.clone/src/mat/utils/matstash.c:906:30: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>      /usr/home/balay/petsc.clone-2/src/mat/utils/matstash.c:906: warning: comparison between signed and unsigned integer expressions
>  src/mat/utils/matstash.c:911
>      /sandbox/petsc/petsc.clone/src/mat/utils/matstash.c:911:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>      /usr/home/balay/petsc.clone-2/src/mat/utils/matstash.c:911: warning: comparison between signed and unsigned integer expressions
>  src/mat/utils/matstash.c:922
>      /sandbox/petsc/petsc.clone/src/mat/utils/matstash.c:922:30: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>      /usr/home/balay/petsc.clone-2/src/mat/utils/matstash.c:922: warning: comparison between signed and unsigned integer expressions
>  src/mat/utils/matstash.c:928
>      /sandbox/petsc/petsc.clone/src/mat/utils/matstash.c:928:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>      /usr/home/balay/petsc.clone-2/src/mat/utils/matstash.c:928: warning: comparison between signed and unsigned integer expressions
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
