[petsc-dev] memory leak
Mark Adams mfadams at lbl.gov
Mon Jun 1 07:22:50 CDT 2015
> Right before you make the branch from master, you should pull. If you
> pull, you will be 0 commits ahead.
Matt, I am not branching from master.  I have checked out maint in the past
week, but don't even think I have do that this clone.
Anyway, I've blown it away and am starting with a fresh clone.
Thanks again,
>    Matt
>> Thanks,
>> Mark
>>>    Matt
>>>> from another branch, at least I did not knowingly.  I am tempted to
>>>> just start with a fresh clone and redo this whole thing.
>>>> What is going on here?  Did I sleep walk last night and pull from next?
>>>> Can I just push this to master (I tested it and it is a trivial change)
>>>> or should I reclone. etc.?
>>>> Mark
>>>> 19:10 edison03 master ~/petsc$ git status
>>>> # On branch master
>>>> # Your branch is ahead of 'origin/master' by 7 commits.
>>>> # Changes not staged for commit:
>>>> #   (use "git add <file>..." to update what will be committed)
>>>> #   (use "git checkout -- <file>..." to discard changes in working
>>>> directory)
>>>> #       modified:
>>>> src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c
>>>> no changes added to commit (use "git add" and/or "git commit -a")
>>>> 19:10 edison03 master ~/petsc$ git commit
>>>> src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c -m"fixed memory leak"
>>>> [master d4dcd7b] fixed memory leak
>>>>  1 file changed, 1 insertion(+)
>>>> 19:10 edison03 master ~/petsc$ git pull origin master
>>>> From https://bitbucket.org/petsc/petsc
>>>>  * branch            master     -> FETCH_HEAD
>>>> Already up-to-date.
>>>> 19:11 edison03 master ~/petsc$ git status
>>>> # On branch master
>>>> # Your branch is ahead of 'origin/master' by 8 commits.
>>>> nothing to commit (working directory clean)
>>>> On Sun, May 31, 2015 at 10:02 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> This is coming from this line (last):
>>>>> #undef __FUNCT__
>>>>> #define __FUNCT__ "PCFieldSplitGetSubKSP_FieldSplit_Schur"
>>>>> static PetscErrorCode  PCFieldSplitGetSubKSP_FieldSplit_Schur(PC
>>>>> pc,PetscInt *n,KSP **subksp)
>>>>>   PC_FieldSplit  *jac = (PC_FieldSplit*)pc->data;
>>>>>   PetscErrorCode ierr;
>>>>>   PetscFunctionBegin;
>>>>>   ierr = PetscMalloc1(jac->nsplits,subksp);CHKERRQ(ierr);
>>>>> I call it with:
>>>>>   KSP::subksp(2)
>>>>>   call PCFieldSplitGetSubKSP(solver%pc,PETSC_NULL_INTEGER,subksp,ierr)
>>>>> The Fortran wrapper is:
>>>>> PETSC_EXTERN void PETSC_STDCALL pcfieldsplitgetsubksp_(PC *pc,PetscInt
>>>>> *n_local,KSP *ksp,PetscErrorCode *ierr)
>>>>>   KSP      *tksp;
>>>>>   PetscInt i,nloc;
>>>>>   CHKFORTRANNULLINTEGER(n_local);
>>>>>   *ierr = PCFieldSplitGetSubKSP(*pc,&nloc,&tksp); if (*ierr) return;
>>>>>   if (n_local) *n_local = nloc;
>>>>>   CHKFORTRANNULLOBJECT(ksp);
>>>>>   if (ksp) {
>>>>>     for (i=0; i<nloc; i++) ksp[i] = tksp[i];
>>>>> Should I just add a PetscFree(&tksp) here?
>>>>> On Sun, May 31, 2015 at 7:24 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> On Sat, May 30, 2015 at 10:51 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>> wrote:
>>>>>>>  Need more details. How can we reproduce this?
>>>>>> I was hoping this would be obvious. a missed free.
>>>>>> What tests use Schur solvers?  I could see if they have the same
>>>>>> problem.
>>>>>>>   Barry
>>>>>>> > On May 30, 2015, at 7:10 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> > This look like there might be a memory leak in PETSc.  Let me know
>>>>>>> if this is not obvious and get more detail.
>>>>>>> > Mark
>>>>>>> > [0]Total space allocated 16 bytes
>>>>>>> > [ 0]16 bytes PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in
>>>>>>> /global/u2/m/madams/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>> >       [0]  PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in
>>>>>>> >       [0]  PCFieldSplitGetSubKSP() line 1665 in
>>>>>>> >       [0]  KSPSetUp() line 247 in
>>>>>>> /global/u2/m/madams/petsc/src/ksp/ksp/interface/itfunc.c
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150601/35723560/attachment.html>
