[petsc-dev] memory leak
Mark Adams mfadams at lbl.gov
Mon Jun 1 07:16:32 CDT 2015
On Mon, Jun 1, 2015 at 8:05 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, May 31, 2015 at 9:20 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> I have asked this question before but I still do not understand what git
>> is doing here.
>> I pulled, made a fix, did a git status, and I see that I am 7 commits
>> ahead of master.  I commit and I am 8 commits ahead of master.  What are
>> these commits?  I have not pulled
> Lets just start with this. If you branch from master, you will not be ANY
> commits ahead:
>   git checkout master
>   git pull
>   git checkout -b knepley/fix-shit
> It sounds like you are creating the branch from a local master that is
> behind.
I don't understand.  I am _on_ master. I also did a fresh clone last week.
I did a git log and I see normal stuff like Barry's fix for GetSubMatrix.
I have been going back and forth to maint.  Perhaps I pulled from maint
into my master by mistake?
>    Matt
>> from another branch, at least I did not knowingly.  I am tempted to just
>> start with a fresh clone and redo this whole thing.
>> What is going on here?  Did I sleep walk last night and pull from next?
>> Can I just push this to master (I tested it and it is a trivial change)
>> or should I reclone. etc.?
>> Mark
>> 19:10 edison03 master ~/petsc$ git status
>> # On branch master
>> # Your branch is ahead of 'origin/master' by 7 commits.
>> # Changes not staged for commit:
>> #   (use "git add <file>..." to update what will be committed)
>> #   (use "git checkout -- <file>..." to discard changes in working
>> directory)
>> #       modified:   src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c
>> no changes added to commit (use "git add" and/or "git commit -a")
>> 19:10 edison03 master ~/petsc$ git commit
>> src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c -m"fixed memory leak"
>> [master d4dcd7b] fixed memory leak
>>  1 file changed, 1 insertion(+)
>> 19:10 edison03 master ~/petsc$ git pull origin master
>> From https://bitbucket.org/petsc/petsc
>>  * branch            master     -> FETCH_HEAD
>> Already up-to-date.
>> 19:11 edison03 master ~/petsc$ git status
>> # On branch master
>> # Your branch is ahead of 'origin/master' by 8 commits.
>> nothing to commit (working directory clean)
>> On Sun, May 31, 2015 at 10:02 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> This is coming from this line (last):
>>> #undef __FUNCT__
>>> #define __FUNCT__ "PCFieldSplitGetSubKSP_FieldSplit_Schur"
>>> static PetscErrorCode  PCFieldSplitGetSubKSP_FieldSplit_Schur(PC
>>> pc,PetscInt *n,KSP **subksp)
>>>   PC_FieldSplit  *jac = (PC_FieldSplit*)pc->data;
>>>   PetscErrorCode ierr;
>>>   PetscFunctionBegin;
>>>   ierr = PetscMalloc1(jac->nsplits,subksp);CHKERRQ(ierr);
>>> I call it with:
>>>   KSP::subksp(2)
>>>   call PCFieldSplitGetSubKSP(solver%pc,PETSC_NULL_INTEGER,subksp,ierr)
>>> The Fortran wrapper is:
>>> PETSC_EXTERN void PETSC_STDCALL pcfieldsplitgetsubksp_(PC *pc,PetscInt
>>> *n_local,KSP *ksp,PetscErrorCode *ierr)
>>>   KSP      *tksp;
>>>   PetscInt i,nloc;
>>>   CHKFORTRANNULLINTEGER(n_local);
>>>   *ierr = PCFieldSplitGetSubKSP(*pc,&nloc,&tksp); if (*ierr) return;
>>>   if (n_local) *n_local = nloc;
>>>   CHKFORTRANNULLOBJECT(ksp);
>>>   if (ksp) {
>>>     for (i=0; i<nloc; i++) ksp[i] = tksp[i];
>>> Should I just add a PetscFree(&tksp) here?
>>> On Sun, May 31, 2015 at 7:24 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> On Sat, May 30, 2015 at 10:51 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>>>  Need more details. How can we reproduce this?
>>>> I was hoping this would be obvious. a missed free.
>>>> What tests use Schur solvers?  I could see if they have the same
>>>> problem.
>>>>>   Barry
>>>>> > On May 30, 2015, at 7:10 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> > This look like there might be a memory leak in PETSc.  Let me know
>>>>> if this is not obvious and get more detail.
>>>>> > Mark
>>>>> > [0]Total space allocated 16 bytes
>>>>> > [ 0]16 bytes PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in
>>>>> /global/u2/m/madams/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>> >       [0]  PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in
>>>>> >       [0]  PCFieldSplitGetSubKSP() line 1665 in
>>>>> >       [0]  KSPSetUp() line 247 in
>>>>> /global/u2/m/madams/petsc/src/ksp/ksp/interface/itfunc.c
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150601/4ccadd41/attachment.html>
