[petsc-dev] memory leak
Mon Jun 1 07:05:13 CDT 2015
On Sun, May 31, 2015 at 9:20 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I have asked this question before but I still do not understand what git
> is doing here.
> I pulled, made a fix, did a git status, and I see that I am 7 commits
> ahead of master.  I commit and I am 8 commits ahead of master.  What are
> these commits?  I have not pulled
Lets just start with this. If you branch from master, you will not be ANY
commits ahead:
  git checkout master
  git pull
  git checkout -b knepley/fix-shit
It sounds like you are creating the branch from a local master that is
behind.
   Matt
> from another branch, at least I did not knowingly.  I am tempted to just
> start with a fresh clone and redo this whole thing.
> What is going on here?  Did I sleep walk last night and pull from next?
> Can I just push this to master (I tested it and it is a trivial change) or
> should I reclone. etc.?
> Mark
> 19:10 edison03 master ~/petsc$ git status
> # On branch master
> # Your branch is ahead of 'origin/master' by 7 commits.
> # Changes not staged for commit:
> #   (use "git add <file>..." to update what will be committed)
> #   (use "git checkout -- <file>..." to discard changes in working
> directory)
> #       modified:   src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c
> no changes added to commit (use "git add" and/or "git commit -a")
> 19:10 edison03 master ~/petsc$ git commit
> src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c -m"fixed memory leak"
> [master d4dcd7b] fixed memory leak
>  1 file changed, 1 insertion(+)
> 19:10 edison03 master ~/petsc$ git pull origin master
> From https://bitbucket.org/petsc/petsc
>  * branch            master     -> FETCH_HEAD
> Already up-to-date.
> 19:11 edison03 master ~/petsc$ git status
> # On branch master
> # Your branch is ahead of 'origin/master' by 8 commits.
> nothing to commit (working directory clean)
> On Sun, May 31, 2015 at 10:02 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> This is coming from this line (last):
>> #undef __FUNCT__
>> #define __FUNCT__ "PCFieldSplitGetSubKSP_FieldSplit_Schur"
>> static PetscErrorCode  PCFieldSplitGetSubKSP_FieldSplit_Schur(PC
>> pc,PetscInt *n,KSP **subksp)
>>   PC_FieldSplit  *jac = (PC_FieldSplit*)pc->data;
>>   PetscErrorCode ierr;
>>   PetscFunctionBegin;
>>   ierr = PetscMalloc1(jac->nsplits,subksp);CHKERRQ(ierr);
>> I call it with:
>>   KSP::subksp(2)
>>   call PCFieldSplitGetSubKSP(solver%pc,PETSC_NULL_INTEGER,subksp,ierr)
>> The Fortran wrapper is:
>> PETSC_EXTERN void PETSC_STDCALL pcfieldsplitgetsubksp_(PC *pc,PetscInt
>> *n_local,KSP *ksp,PetscErrorCode *ierr)
>>   KSP      *tksp;
>>   PetscInt i,nloc;
>>   CHKFORTRANNULLINTEGER(n_local);
>>   *ierr = PCFieldSplitGetSubKSP(*pc,&nloc,&tksp); if (*ierr) return;
>>   if (n_local) *n_local = nloc;
>>   CHKFORTRANNULLOBJECT(ksp);
>>   if (ksp) {
>>     for (i=0; i<nloc; i++) ksp[i] = tksp[i];
>> Should I just add a PetscFree(&tksp) here?
>> On Sun, May 31, 2015 at 7:24 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> On Sat, May 30, 2015 at 10:51 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>>  Need more details. How can we reproduce this?
>>> I was hoping this would be obvious. a missed free.
>>> What tests use Schur solvers?  I could see if they have the same problem.
>>>>   Barry
>>>> > On May 30, 2015, at 7:10 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> > This look like there might be a memory leak in PETSc.  Let me know if
>>>> this is not obvious and get more detail.
>>>> > Mark
>>>> > [0]Total space allocated 16 bytes
>>>> > [ 0]16 bytes PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in
>>>> /global/u2/m/madams/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>> >       [0]  PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in
>>>> >       [0]  PCFieldSplitGetSubKSP() line 1665 in
>>>> >       [0]  KSPSetUp() line 247 in
>>>> /global/u2/m/madams/petsc/src/ksp/ksp/interface/itfunc.c
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150601/1a0d5752/attachment.html>
