[petsc-dev] Julia Petsc Wrapper
Jed Brown jed at jedbrown.org
Tue Jul 28 00:22:55 CDT 2015
Jared Crean <jcrean01 at gmail.com> writes:
>          As for the MPI communicator, the julia MPI package uses a C int
> to store it, so I will typealias to that to ensure consistency.  If an
> MPI implementation uses an 8 byte pointer, MPI.jl will have to change too.
Open MPI and relatives (like the now-obsolete LAM-MPI) use a pointer for
all handles.  To my knowledge, there is no subset of the MPI interface
that can reliably be called to determine the binary interface, so you'll
need access to the headers there too.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150727/f310af94/attachment.sig>
