[petsc-dev] Julia Petsc Wrapper
Jared Crean jcrean01 at gmail.com
Tue Jul 14 21:55:35 CDT 2015
     Hello,
         It works!  Just tested it for the complex case.  Someone was
clever enough to make it work for "Scalar" even though it isn't a
PetscDataType.
     Thanks for the help,
         Jared Crean
On 7/14/2015 10:40 PM, Matthew Knepley wrote:
> On Tue, Jul 14, 2015 at 9:35 PM, Jared Crean <jcrean01 at gmail.com
> <mailto:jcrean01 at gmail.com>> wrote:
>         Hello,
>             PETSC_SCALAR is not a symbol either.  I skimmed through
>     the names in the shared library, and it doesn't look like any data
>     type information is there.
> Damn, yes PETSC_SCALAR and PETSC_REAL are defines. I think we are
> careful about this so that you can use
> a real and complex PETSc together by building multiple versions of the
> library (no symbol clash). However, I believe
> you can use
>   PetscDataTypeFromString("scalar", &stype, &found);
>   PetscDataTypeFromString("complex", &ctype, &found);
>   isComplex = stype == ctype;
>   Thanks,
>     Matt
>             Jared Crean
>     On 7/14/2015 9:22 PM, Matthew Knepley wrote:
>>     On Tue, Jul 14, 2015 at 8:03 PM, Jared Crean <jcrean01 at gmail.com
>>             Hello,
>>                 PETSC_USE_COMPLEX isn't a symbol in the shared
>>         library when Petsc is built with complex scalars, so I don't
>>         see a way to access it at runtime. I'll have to write a
>>         simple C program that uses sizeof() and write the value to a
>>         file.
>>     That is crazy. How about
>>       isComplex = PETSC_COMPLEX == PETSC_SCALAR
>>        Matt
>>                 As for the MPI communicator, the julia MPI package
>>         uses a C int to store it, so I will typealias to that to
>>         ensure consistency.  If an MPI implementation uses an 8 byte
>>         pointer, MPI.jl will have to change too.
>>             Jared Crean
>>         On 7/14/2015 1:04 PM, Matthew Knepley wrote:
>>>         On Tue, Jul 14, 2015 at 10:56 AM, Jared Crean
>>>         <jcrean01 at gmail.com <mailto:jcrean01 at gmail.com>> wrote:
>>>                 Hello everyone,
>>>                     I got the package in a reasonably working state
>>>             and Travis testing setup, so I am putting the package up
>>>             on Github.
>>>             https://github.com/JaredCrean2/PETSc.jl
>>>                     There is still a lot more work to do, but its a
>>>             start.
>>>                     A couple questions:
>>>                     When looking though the code, I noticed the MPI
>>>             communicator is being passed as a 64 bit integer.  mpi.h
>>>             typedefs it as an int, so shouldn't it be a 32 bit integer?
>>>         Some MPI implementations store the communicator as a
>>>         pointer, which may be 64 bits. I think the only thing the
>>>         standard says is
>>>         that MPI_Comm should be defined.
>>>                     Also, is there a way to find out at runtime what
>>>             datatype a PetscScalar is?  It appears
>>>             PetscDataTypeGetSize does not accept PetscScalar as an
>>>             argument.
>>>         If PETSC_USE_COMPLEX is defined its PETSC_COMPLEX, otherwise
>>>         its PETSC_REAL. You can also just use sizeof(PetscScalar).
>>>         What do you
>>>         want to do?
>>>           Thanks,
>>>              Matt
>>>                 Jared Crean
>>>             On 07/06/2015 09:02 AM, Matthew Knepley wrote:
>>>>             On Mon, Jul 6, 2015 at 4:59 AM, Patrick Sanan
>>>>             <patrick.sanan at gmail.com
>>>>             <mailto:patrick.sanan at gmail.com>> wrote:
>>>>                 I had a couple of brief discussions about this at
>>>>                 Juliacon as well. I think it would be useful, but
>>>>                 there are a couple of things to think about from
>>>>                 the start of any new attempt to do this:
>>>>                 1. As Jack pointed out, one issue is that the PETSc
>>>>                 library must be compiled for a particular
>>>>                 precision. This raises some questions - should
>>>>                 several versions of the library be built to allow
>>>>                 for flexibility?
>>>>                 2. An issue with wrapping PETSc is always that the
>>>>                 flexibility of using the PETSc options paradigm is
>>>>                 reduced - how can this be addressed? Could/should
>>>>                 an expert user be able to access the options
>>>>                 database directly, or would this be too much
>>>>                 violence to the wrapper abstraction?
>>>>             I have never understood why this is an issue. Can't you
>>>>             just wrap our interface level, and use the options just
>>>>             as we do? That
>>>>             is essentially what petsc4py does. What is limiting in
>>>>             this methodology? On the other hand, requiring specific
>>>>             types, ala FEniCS,
>>>>             is very limiting.
>>>>                Matt
>>>>                 On Sat, Jul 4, 2015 at 11:00 PM, Jared Crean
>>>>                     Hello,
>>>>                          I am a graduate student working on a CFD
>>>>                     code written in Julia, and I am interested in
>>>>                     using Petsc as a linear solver (and possibly
>>>>                     for the non-linear solves as well) for the
>>>>                     code.  I discovered the Julia wrapper file
>>>>                     Petsc.jl in Petsc and have updated it to work
>>>>                     with the current version of Julia and the
>>>>                     MPI.jl package, using only MPI for
>>>>                     communication (I don't think Julia's internal
>>>>                     parallelism will scale well enough, at least
>>>>                     not in the near future).
>>>>                          I read the discussion on Github
>>>>                     [https://github.com/JuliaLang/julia/issues/2645],
>>>>                     and it looks like
>>>>                     there currently is not a complete package to
>>>>                     access Petsc from Julia. With your permission,
>>>>                     I would like to use the Petsc.jl file as the
>>>>                     basis for developing a package.  My plan is
>>>>                     create a lower level interface that exactly
>>>>                     wraps Petsc functions, and then construct a
>>>>                     higher level interface, probably an object that
>>>>                     is a subtype of Julia's AbstractArray, that
>>>>                     allows users to store values into Petsc vectors
>>>>                     and matrices. I am less interested in
>>>>                     integrating tightly with Julia's existing
>>>>                     linear algebra capabilities than ensuring good
>>>>                     scalability. The purpose of the high level
>>>>                     interface it simple to populate the vector or
>>>>                     matrix.
>>>>                          What do you think, both about using the
>>>>                     Petsc.jl file and the overall approach?
>>>>                          Jared Crean
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150714/a220e16e/attachment.html>
