[petsc-dev] [SLEPc - GPU] Problems running SLEPc on GPUs
Leoni, Massimiliano Massimiliano.Leoni at Rolls-Royce.com
Fri Jul 24 03:09:51 CDT 2015
Hi everybody,
I have recently being trying to run SLEPc on GPUs, but I am experiencing some trouble.
I think I correctly installed PETSc to run on GPUs, as I can actually see an execution time difference in PETSc programs when run with or without -vec_type cusp -mat_type aijcusp.
When I try to do the same with SLEPc, I get the following error [running hands-on exercise 2]
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Cannot create a BVSVEC from a non-standard template vector
>From the documentation I understood this BVSVEC is a base SLEPc type, so I am not sure how to interpret this [wouldn't know what to touch at high-level].
Can anyone please point me to some examples/documentation on this?
Thanks in advance
Massimiliano Leoni
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 1332 622800(Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
(c) 2015 Rolls-Royce plc
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150724/8c2e8194/attachment.html>
